chain hoist
Old Jul 21, 2009 | 06:16 PM
rockethound's Avatar
Lightbulb chain hoist
hey guys i have a 1 ton chain hoist to help lift engine blocks out of the and on to stand or onto a bench. bye the way that was the intent of purchasing the hoist. just not sure how to hang it? the barn is two story. didn't now if i should put a 4x6 across the floor upstairs and hang it down through a hole or should i make a frame out of some 4x4s with a 4x6 across the top? i need help any ideas.
thanks
Old Jul 21, 2009 | 07:15 PM
citcapp's Avatar
Make the frame, Use 4x6 for the uprights and 4x8 for the cross member be safe
Old Jul 22, 2009 | 02:14 AM
jensenracing77's Avatar
when i used a hoist back when, i just took a couple 2X4s and tossed across a couple trusses and hooked the hoist to it. the only thing about this is when you get the engine up you have to move the car backward. with a cherry picker all you have to do is roll the engine where you want it.
Old Jul 22, 2009 | 05:21 AM
wolfman98's Avatar
Captain of my ship
lift
I just finished helping a guy take a motor out of his truck and put a new one in.took about 30 minutes to do using my big blue mobile lift.
Old Jul 22, 2009 | 05:30 AM
frame
I've seen a steel frame with rollers in my friends ole trimey garage. It looks kinda like a swing set with rollers on the 4 corners and the chain hoist in the center. Only problem is the Hood has to come off to lift the engine.
Old Jul 22, 2009 | 05:27 PM
dale keener's Avatar
I plan on usin a sawmill 4x4 real 4 inch to support my chain hoist tranny not attatched is what 600 pds? 425 whadda ya think?
Old Jul 23, 2009 | 04:11 AM
The only problem I have had with rough cut lumber is it can have knots and flaws that could allow it to snap. Check it out visually good for blemishes.
Old Jul 23, 2009 | 09:03 AM
citcapp's Avatar
X2 on that as I stated earlier in this thread I think a 4 x 4 is not big enough to allow for a safety margin. It does depend a lot on the grade of the lumber being used. Clear fir being the best, it goes down hill from there.
Old Jul 23, 2009 | 05:29 PM
ok sounds like a 6X6 from lowes is needed
oldspackrat
Apr 17, 2013 07:59 PM
had a few c.s
Sep 3, 2012 06:01 AM
Al2011
Jul 22, 2011 03:18 PM
1973olds98
Oct 15, 2009 04:03 PM
Jolly Green
Apr 2, 2008 01:04 PM
