carb pedal interface
Old Sep 18, 2013 | 01:49 PM
joepenoso's Avatar
Question carb pedal interface
I got a new stock cable for my 1971 442 with a quadrajet. What holds the gas pedal side of the cable??
It has a crimped soldered thing and came with blurry instructions-- pictures but I am not sure how it attached stock?
joepenoso
Old Sep 18, 2013 | 03:07 PM
brddg's Avatar
Do you have the original cable? Mine has a plastic "bushing" with a slot in it to slide the cable (sideways) through and the crimped part will butt up against that while the other end of the "bushing" is pointed to center and stay in the pedal arm.
Old Sep 18, 2013 | 03:55 PM
joepenoso's Avatar
Red face
I guess that's what I'm asking.......I don't have that plastic part. I will try to keep it original and not use the aluminum squeeze garage door cable thingy. Any suggestions where to order the part...........preferably where you don't have to order $50.00 pf stuff before they consider your order?
joepenoso
Old Sep 18, 2013 | 05:35 PM
brddg's Avatar
Ouch. Just remembered that I cut that slot in the bushing from a donor car. Sorry. I see what you mean though, none of my parts catalogues have that listed. Might be time to get creative, unless someone else wants to chime in here?
Old Sep 18, 2013 | 06:13 PM
I'm pretty sure that the same little bushing was used in darn near all GM cars late-'60s through '70s, and possibly into the '80s.
It's got an OD that just fits snugly in the hole in your gas pedal lever, and ID that lets the cable core slide through easily, a flare on one end to stop it against the pedal lever, and a slit along it wide enough to slip it over the cable core.
It's called the throttle cable to accelerator pedal retainer, #403929.
You could make one out of something else if you were desperate, but you should be able to find one easily enough.
Old Sep 18, 2013 | 07:00 PM
joepenoso's Avatar
Thanks that was very helpful
joepenoso
brown7373
Sep 23, 2017 08:07 PM
frankr442
Jan 20, 2015 07:18 AM
tarps3
Brakes/Hydraulic Systems
Jun 29, 2008 05:00 AM
mcutlass1969
May 31, 2008 04:48 AM
Dapapadon
Jan 21, 2008 10:27 PM
