Car fires and what to use
Old August 11th, 2010, 09:52 AM
  #41
Past Administrator
Oldsguy's Avatar
Originally Posted by stevengerard
Is there a battery quick disconnect that can mounted in the floor near the drivers seat. My issue (and I am sure others have) is the W25 hood can be a bear to open - those precious seconds can turn into minutes and the car is burned.
Possibly, or a person could try to fabricate an on/off toggle switch similar to your high beam switch to do the job but the problem is you want the disconnect to be as close as possible to the battery. Both ideas have drawbacks and you can't foresee every possible complication that might crop up. For instance, what if there were a fire on both sides of the firewall or perhaps just smoke in the engine compartment? The moment you pop the hood you are going to be engulfed in smoke and heat. You already mentioned the delay in time with a W25 hood.
Oldsguy is offline
Old August 11th, 2010, 10:02 AM
  #42
Grown Azz Kid
Olds luvr's Avatar
Well here is the idea I am going to look at. Bassicly have the kill switch in the engine compartment by the battery and use one of these T handle pulls mounted under the dash. Pulling the handle will pull the Key out of the switch and you will not have to get out and open the hood and allows more time to do what is needed. Also prevents from running too many wires over a longer distance. Not sure this is ideal or not but just what I was thinking
Olds luvr is offline
Old August 11th, 2010, 12:39 PM
  #43
Lady72nRob71's Avatar
Kinda like a lanyard kill mechanism in jet ski or such - neat idea!
Lady72nRob71 is offline
Old August 11th, 2010, 01:03 PM
  #44
Grown Azz Kid
Olds luvr's Avatar
Rob, I was thinking of my boats system that is where I got the idea but remembered that jet skis and boats are just ignition. This way helps for a fire in the engine bay as well. Who has time to go open the hood when the car is burning. Could even get creative and make it look stock with the inside hood lock release
Old August 11th, 2010, 01:17 PM
  #45
I was told but haven't seen it yet that Auto Zone has one that works like a breaker.
Then again, I think you are running into the same problem I had with the amp meter inside the car. You're bringing hot power into the passanger side of the fire wall.
Jamesbo is offline
Old August 11th, 2010, 02:53 PM
  #46
BlackGold's Avatar
Just remember that if the battery is supplying enough current to start a fire, then the cables and terminals at the battery might be quite hot as well. It's possible that a quick disconnect will be too hot to touch or won't operate.
I once watched a stock-class dragracer scramble to try to resolve a short circuit when his starter cable melted then welded itself to a header pipe. Using a wrench to disconnect the battery -- while the battery is heating up exponentially due to the dead short -- sounds like a good way to get a face full of acid.
I'm thinking that one of the best emergency tools to have on hand is a large pair of "dikes" aka diagonal cutter or wire cutter. I know that's the first tool the fire department uses when they are called to an accident scene. For most shorts, the only wire you have to cut is the fusible link coming off the battery + terminal. If that doesn't stop it, you can choose betwen the thick positive or negative cables.
BlackGold is offline
Old August 11th, 2010, 03:51 PM
  #47
msco123's Avatar
Great idea! A set of heavy duty wire cutters are going in my cars with tht extinguisher. Where do you guys keep your extinquishers?
msco123 is offline
JpMotorsports
May 15th, 2014 07:08 AM
Miles71
May 12th, 2014 03:19 PM
rlang
August 23rd, 2013 05:55 PM
Jaybird
January 7th, 2011 07:28 AM
ChrisM
July 9th, 2009 03:40 AM
Quick Reply: Car fires and what to use
