Can hole in convertible top be repaired?
My top is in pretty good shape except for one spot that I noticed has become a hole and seems to be growing each time I raise and lower the top.
Is there anything I can do to stop it from becoming larger and forcing me to get a new top sooner than I'd like? It is only the top layer that is torn, the secondary black layer is fine. Any way I can stitch it?
<a data-flickr-embed="true" href="https://www.flickr.com/photos/48666605@N00/27202179751/in/dateposted-public/" title="IMG_0037"><img src="https://c8.staticflickr.com/8/7357/27202179751_09df00f696_z.jpg" width="640" height="480" alt="IMG_0037"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Closeup view:
Thanks,
Bill
Closeup view:
Thanks,
Bill
My top developed a hole in that location shortly after I installed it - I think I had the material too tight in that area. Anyway, I patched it with a small piece of top material that I think was left over from the front bow area after I did some trimming during the install. I cleaned around the hole very well using a solvent, cut the patch into a rounded shape so there weren't any corners to lift, then glued it over the hole using 3M weatherstrip adhesive. That patch held for over 10 years and wasn't very noticeable, but my top is black (as was the adhesive) so it didn't stand out.
That's the place where they tear, and it's usually a steady process of deterioration from here.
You can try to patch it, and that may work for a while, but in the end, it will be a 12" tear, especially once the wind gets at it.
You do most of your driving with the top down anyway, right?
Thanks for the replies guys. Kind of what I feared/expected, similar to a small crack in a windshield...over time it just gets larger.
Guess its time to start saving my pennies for a new top to be installed next year. I fear this is about a $1500 hit from what I understand...bummer!
Non Oldsmobile. I have repaired a hole (very small 3/8 inch ) by using a strip of woven nylon belt material same color as the top (black) and a thin layer of epoxy glue. It has held up for over 6 months so far, looks good and it is put up and down a lot..... Tedd
I have the same issue now on both sides and know a top replacement is in my future. In the meantime, I glued a patch of black vinyl on the backside and used tear-aid on the exterior. Another reason to drive top down most of the time....
Closeup view:
Thanks,
Bill
Closeup view:
Thanks,
Bill
Back when I had convertibles, I used to put the top half down then get out and chop a fold in each side before putting it all the way down to prevent the sharp outward folds that would develop. Not sure what the owner's manual says but I would start there for preventative maintenance.
Thanks for the replies!
Took it to my upholsterer today and he said the reason this happened was the padding inside didn't extend far down enough and the top wore on the metal knuckle over time.
Bringing it in next week for a patch and additional padding he recommended to get me thru the summer and hopefully beyond...?
Hurst/Olds 73/74
September 12th, 2013 08:12 PM
