can this be fixed
Old Nov 14, 2014 | 05:35 AM
69442murph's Avatar
can this be fixed
the mounting tab on this altenator is messed up, and I would like to know if there is a way to fix it? Can it be filled with weld and helicoiled? thanks
Old Nov 14, 2014 | 05:44 AM
dc2x4drvr's Avatar
Tig weld and helicoil.
cherokeepeople's Avatar
pull it apart and take it to a machine shop and have them weld it shut.then redrill and tap it.
Old Nov 14, 2014 | 05:47 AM
Well, looks like some Ethiopian engineering is in order. You fill weld, drill and tap. Sleeve it and just use a nut, bolt, and washer...etc. Or buy another core and swap cases. Then again you can circumvent all the headaches and just get another one.
Old Nov 14, 2014 | 06:05 AM
dc2x4drvr's Avatar
I believe that's a fairly rare open face alternator, hard to find another one.
Old Nov 14, 2014 | 06:21 AM
69442murph's Avatar
it is off a 69 442, so it is the open face 37amp alt. I want to save it, and reuse it, as these are hard to find today, and it is an original dated, stamped, alt.
thanks for taking the time to respond. I will look into a machine shop to do the repairs.
Will post pics of the before and after outcome!
thank you
Old Nov 14, 2014 | 06:22 AM
Sorry, didn't look at the whole picture just the mounting hole. A bit of creativity can still fix it and have it look nice.
Old Nov 16, 2014 | 05:40 PM
67442nut's Avatar
x 2.
That's the best fix.
Do it right and it'll be hard to tell it was ever done.
Old Nov 16, 2014 | 05:59 PM
TK-65's Avatar
thank you
Yes, do NOT take it to any machine shop. Send it to someone that does those types of repairs.
http://www.kenbrunomotorsports.com/main.html
He fixed my club coupes alternator.
Old Nov 19, 2014 | 03:23 PM
stellar's Avatar
stellar
Ken does excellent work and I recomend him highly. However, the repaired end frame looks to be a replacement and not the same one. So this makes me wonder if it was repaired or replaced. The fan is different too. I think the original fan is the correct one if it is for a 65. Take a look at the upper edge of the casting. It is different. In any case it is a fantastic job done by Ken Bruno.
esisson
May 20, 2008 12:09 PM
tiparosa
Mar 3, 2007 03:48 PM
