camless engine
Old Dec 21, 2016 | 08:20 AM
camless engine
I can see a catastrophic failure with a stuck/faulty valve. I can also see some advantages.
http://www.roadandtrack.com/new-cars...tion-in-china/
Old Dec 21, 2016 | 08:35 AM
Because that's such a common problem?
Cam-less engines have been "near" production for decades. The problem has always been that the actuators can't move fast enough at high RPMs. Keep in mind that at 5,000 RPM, each valve opens and closes 42 times a second. Of course, the ability to electronically change the "cam" profile on the fly has always been the holy grail.
Old Dec 21, 2016 | 10:12 AM
svnt442's Avatar
svnt442's Avatar
Old Dec 21, 2016 | 10:36 AM
I'm impressed.
And it looks like the same system could be adapted to American V8 heads, with a "certain" amount of engineering.
Old Dec 24, 2016 | 07:19 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Direct injection, variable valve timing and cylinder deactivation were also out of reach a few years back, not anymore. Give it a few years and it could be common place.
Old Dec 24, 2016 | 07:32 AM
Considering that the video said that it's cheaper, occupies less space, and weighs less, and considering that further improvement is inevitable, I'd say that it will be commonplace.
My only question is how progress in this area and progress in electric motors and energy storage will develop - if electrics get a lot better a lot faster, this technology may be left behind as a promising dead end.
Old Dec 24, 2016 | 07:37 AM
I don't think I've ever read or seen a press release for a new technology that claimed it sucked as compared to the current state of the art...
Just sayin'...
Old Dec 24, 2016 | 08:00 AM
Fine. Be that way.
Old Dec 24, 2016 | 08:28 AM
76olds's Avatar
Hookers under Hood
The are making the new cars much lighter now as we know and the future is lighter .
What scares the heck out of me is, A little fiat POS was side by side with me on Hwy 10 a few days ago with high winds and blowing snow. Good thing I was in the left lane because suddenly a burst of wind actually blew my car over a bit but I hung onto it (G8 winter beater), but the little fiat went out of the tire tracks, hit the loose snow and off he/she went into the ditch. I see many of these little cars that can't handle mother natures wind speeds at times.
I'm gettin worried.
Old Dec 24, 2016 | 08:54 AM
These tiny little pieces of crap were built to be used on the small narrow streets of Italy and other European countries. Then they import them over here and you saw what happens. If they only drove them in large cities they would probably be okay. I think they are death traps.
I'm struggling to understand what a discussion of tiny cars has to do with a thread about camless engines...
Old Dec 24, 2016 | 09:11 AM
redoldsman's Avatar
Proud Viet Nam Veteran
Mine was a response to 76Olds. I have deleted the response so not to offend anybody.
Old Dec 24, 2016 | 09:18 AM
76olds's Avatar
Hookers under Hood
I suppose I created your struggle. I hope it doesn't last long, its just my theory of lighter weight. Loosen up Joe.
Eric
Old Dec 24, 2016 | 09:19 AM
Eric
Sorry, but it's still thread hijacking.
Old Dec 24, 2016 | 09:25 AM
76olds's Avatar
Hookers under Hood
I get ur point. Its time to start Jackin' myself up and leave this thread alone here lol. Sorry to trip'
n' here on ya'
Cheers
Eric
Old Dec 25, 2016 | 01:18 PM
Seff's Avatar
Torque should theoretically be constant for any given engine across the RPM range. The reason it isn't is the cam profile being optimal only for a certain RPM range. If cams were deleted, and valves could be controlled directly, this would all change.
Theoretically both direct injection and camless valves can be retrofitted to old American iron. But I'm more interested in it being applied to new cars ASAP, to make cars less dirty. I like my air clean.
Old Dec 25, 2016 | 07:56 PM
cjsdad's Avatar
I'm gettin worried.
To continue and feed fuel to the hijack, I have (my wife has) a 2012 Mini Cooper Countryman ALL-4. Small, lightweight, fast as hell, and imported, but it is the best vehicle I have ever driven in winter weather conditions. The "ALL-4" system puts the drive train in 4-wheel drive at low speeds, all-wheel drive above about 35-40 MPH and front-wheel drive above 80-85 MPH. It handles better on icy/snowy roads than my 2012 Dodge 2500 4X4 or the '02 Expedition 4X4 it replaced. So don't go selling the small cars short.
File Type: gif
File Type: gif
Old Dec 26, 2016 | 12:09 AM
shiftbyear's Avatar
a pneumatic valve train has been in use since the 1980's, designed by Renault. Formula 1 uses it and is good at 20,000 rpms. I imagine a combination of electric/pneumatic valve train with computer controlled timing would give a substancial increase over camshaft actuated valves. good post
Old Dec 26, 2016 | 07:34 AM
76olds's Avatar
Hookers under Hood
[QUOTE=cjsdad;977981]To continue and feed fuel to the hijack, I have (my wife has) a 2012 Mini Cooper Countryman ALL-4.
Hey, listen mister! Don't go wasting the fuel haha. I'll give you that one, Mini Coopers are OK, My sister owns one as well and she loves it.
Cheers
Eric
Old Dec 27, 2016 | 09:32 AM
quaddriver's Avatar
4 Barrels of Laughs
From: I moved to pittsburgh so I can be near Primantis
gm has messed with this for years and while it will work for a while, it will not work with a proper MTBF for a warranty that wont make people head to toyota....they have even played with different IC technologies essentially abandoning the otto cycle (read: rotary and miller cycle, both of which mazda pumped a few hundred mil into....)
the hydraulic method was too complex and to quick to physically break, the electronic method suffered from a lot of problems from coil saturation with solenoids to extreme heat fatigue for electronic components.
while it would be interesting, I dont think outside the lab its feasible. especially with longevity concerns
Old Dec 27, 2016 | 09:36 AM
quaddriver's Avatar
4 Barrels of Laughs
torque WOULD be constant if the one wild card (well ok, 2) volumetric efficiency (first order effect) and the resulting dynamic compression ratio change (second order) could be manipulated. Cam profile is only part of this, intake size and shape is the other, hence turbocharging rears its ugly head again
Old Dec 29, 2016 | 11:35 AM
davebw31's Avatar
Navistar had a mid size camless engine for class 5 trucks and school bus application. When I first saw it in a school bus they had already had 200.000 miles on it driving around the county. It had a design C Life Cycle. It was a pretty neat engine with a shorter deck height due to no cam, push rods, etc. This low deck allowed for a radically tapered hood for better aero. I was told by Navistar engineers and the sales people it was not cheap to build. This was in the very late 90 s.
805cut
May 3, 2012 08:11 PM
Olds luvr
Mar 17, 2010 06:57 PM
njot33
Sep 25, 2009 09:07 AM
cts-v
Jan 10, 2009 06:20 PM
pinky
Oct 1, 2007 11:24 AM
