A/c Tension 307
Old Feb 11, 2019 | 05:54 AM
87Brougham307's Avatar
A/c Tension 307
Wich bolts i have to lose to move the A/c compressor on a 307 engine?
I have already the one on the right side bottom.
Old Feb 11, 2019 | 09:22 AM
rustyroger's Avatar
'87 Delta 88 Royale
There should be two more about 150 degrees from the one you already took off. Did you break the 1/2" square drive because you hadn't loosened the right bolts?.
Roger.
Old Feb 11, 2019 | 02:27 PM
You need to loosen the bolt in the slot on the bottom bracket and the pivot bolt.
71DP
May 26, 2019 06:26 PM
Aceshigh
Oct 19, 2010 09:32 AM
oldzy
Oct 14, 2010 09:11 AM
easytobedead
Apr 17, 2010 06:51 PM
84delta88
Dec 6, 2006 06:25 AM
