A/C Heater Vacuum noise
Old Apr 15, 2014 | 08:39 AM
ostie13's Avatar
I have a 71 Toronado and have had to add a vacuum pump because of the cam im running has caused low vacuum so my power brakes were not function.Soon as I add the vacuum pump my brakes started working fine but it has caused a hissing noise behind my A/C controls in the dash.It will only stop when I slide the colder/warmer control lever all the way on cold.Just wanted to know why it is doing this.It was not doing this before the addition of the vacuum pump.Is it possible there is to much vacuum?I just have put the car on the road a few weeks ago ofter the motor rebuild and do not have the compressor for the AC lines hooked up.I would really appreciate your help on this. Thanks Roy
Old Apr 15, 2014 | 08:46 AM
Professur's Avatar
Likely you've a vac leak in the dash. Maybe your low vac issue wasn't entire due to the cam, but because of a leaking diaphragm. Slapping a high vac source into the mix may have blown that leak wide open.
Old Apr 15, 2014 | 08:58 AM
Yes, sounds like a leak in the valve or the lines that control the hot water valve.
I am not 100% certain of the function in each year, but it sounds like your valve closes when vacuum is not applied, and opens when vacuum is applied, thus, when your Temp control is anywhere but "full cold," the control valve to the water valve is open, and vacuum is leaking, instead of being transmitted to the hot water valve, as it should be.
Old Apr 15, 2014 | 12:54 PM
ostie13's Avatar
Thanks for the advice.I will take it apart and let you know what I find.Seems there are several lines that are going to the controller.?
Old Apr 15, 2014 | 01:32 PM
Yes there are. Check the diagram in your Chassis Service Manual.
5998DownUnder
Jun 9, 2014 09:35 AM
tds
Jan 22, 2014 11:05 AM
starfire
Nov 5, 2013 08:37 AM
tmbrennan
Apr 22, 2012 05:36 AM
dschallock
Apr 14, 2011 05:27 PM
