A/C acutators
Old Yesterday | 11:46 AM
stephenca118's Avatar
A/C acutators
Anyone ever find a lead on the heater/AC box door actuator diaphragms? I did find the part numbers such as 3143613 and a few others.
This is the one I am looking for, I think they take a 1/8 inch vac tube.
Old Yesterday | 12:59 PM
Jungle Cat's Avatar
They are pretty common. All GM A body should be the same. Buicks and Olds 70-72 cars I have worked on should be the same. It should be an easy find if you look,
Old Yesterday | 01:04 PM
rocketraider's Avatar
Oldsdruid
See if the part number crosses over to Chevrolet or Pontiac. If it's the same as full-size Chevrolet you're all set.
I know 63-64 all GM B bodies use the same heater box and ducting but not sure on 61-2. I can't remember ever seeing a 61-2 Chevrolet with factory in-dash airconditioning. Most were all underdash units.
Old Yesterday | 02:30 PM
Charlie Jones's Avatar
Phantom Phixer
I found mine for a '63 Olds on E-Bay.
Someone is re-producing them with a six inch wire.
You simply cut the wire to the length you need.
Check with Cadillac suppliers like McVey's. They may have them.
Old Yesterday | 02:38 PM
Thanks all, That would work, it is for the divert valve, if it don't divert then no A/C. I have checked epray, no luck, I will check for other brands, thank you all for the help.
Old Today | 08:56 AM
Oldskeeper's Avatar
For my 62 wagon I bought from OPGinc, part # CE05660 and I ordered 4 units. This was during covid shut down and it took them almost a year to fill (one right away and 3 pieces11 months later). They work correctly for the doors. The unit I'm having trouble with is the vacuum actuated on/off valve behind the inner fender for the freon.
Old Today | 09:20 AM
Thank you for the feed back Oldskeeper, I think I found it, and it was not easy. The company is called Old Air Products. But you enter your car info and it only lists a clamp for A/C parts available. If you enter "Actuator" in the search line it lists a few, but none with the wire. Probably for the air doors, but I needed the one with the wire.
So I went to a Buick site and found a picture of what looked like one that might work so I called and he said he has no part number cross reference for Olds and could not help me.
So I took his part number VD235901 and compared it to the Old Air part numbers, deleted the VD and put a dash after the 23 and voila! 23-5901 is the part number.
I have one on order, It should fit, but we shall see.
If anyone needs HVAC actuators they have a large selection.
Thanks again for the help and I hope this information will help others.
Old Today | 11:45 AM
Phantom Phixer
That's the one I got too. Just cut the wire off to the length you need.
I think it fits most GM cars.
Old Today | 06:18 PM
Oldskeeper's Avatar
Those are the ones I purchassed as well from OPG. They work great and were easy to install.
Steve
OLDsBARRY
Jan 24, 2025 03:09 PM
rgs455
Nov 23, 2024 03:54 AM
Will22
Aug 5, 2018 08:18 AM
yalikeme
Aug 29, 2015 11:51 AM
delta fog
Jun 13, 2012 09:14 PM
