buick v6 in a firenza
Old Apr 18, 2019 | 05:55 PM
deadeyejedi's Avatar
been working on a broken timing chain cover bolt for a few days now and finally was able to drill out the rusted in bolt and retap it (easy outs suck!).i found a lot of slack in the timing chain so i replaced the timing chain and gears with a cloyes unit .removing the harmonic balancer and crank shaft gears on these little buick engines is a breeze compared to my olds engines .no pullers needed.so i get to replacing the harmonic balancer seal in the timing chain cover and it was and old rope seal. my new seal is more of a rubber style that just seems to keep popping out after i seat it where it goes.anyone at all ever changed these to the newer style and run into this problem?i dont know if i can even get the old style anymore .
Old Apr 19, 2019 | 04:08 AM
toymobile's Avatar
You must have the wrong seal, GOOGLE is your friend. LOL
Old Apr 19, 2019 | 02:17 PM
the seal came in a gasket kit for the 231 v 6 and all other gaskets were perfect im assuming this seal is a more modern style .at any rate i rtv and clamped it in place and dimpled the housing to hold the metal portion in and thing are good .thanks for the reply
Old Apr 19, 2019 | 03:09 PM
RetroRanger's Avatar
72 Olds CS
Google is not your friend, dont ever think it is
Guillaume
Aug 20, 2018 01:31 AM
Bryan Burch
Mar 24, 2018 09:44 PM
hackmansr
May 23, 2016 10:01 AM
1978 Oldsmobile Omega
Aug 22, 2015 03:16 PM
Napoleon1991
May 7, 2014 08:38 AM
