Brake issues
Brake issues
I am having some issues with my brakes on my 79 Hurst. End of last summer was braking and pedal went to floor brake light came on. This happened again this year. I replaced the control valve. Fluid is full, and no fluid leaking. Rubber vacum line and metal line to carb have no leaks as I can see. When car is in gear is when it goes to the floor and brake light comes on. In park or neutral brake feels fine no brake light comes on when brake pedal is pressed. Thanks any info would be great. Brian
This is a classic symptom of master cylinder failure.
Inspect the complete brake system, if nothing is excessively worn or leaking just replace the master cylinder. Not much else that can cause the pedal to sink to the floor.
Hipster84Olds
Brakes/Hydraulic Systems
30
Jun 15, 2017 04:05 PM
