Brackets - gas tank brackets
Old Jan 17, 2021 | 10:25 AM
Kelleycougar70's Avatar
Have a question. A mechanic said my gas tank is about to fall off. I just reviewed and though there is rust I don’t see if at a critical level.
With that said, my 17 year old wants to take the car to the prom. So I want it to be safe.
I will buy new straps but any idea where to get the brackets and bolt holders if I need to weld new ones on?
Old Jan 17, 2021 | 12:36 PM
2blu442's Avatar
I think you might be able to get reproduced supports that would be the entire length of the piece between the brackets. Depending on what year/model your car is someone here might have good used parts they would cut off for you to weld on.
Old Jan 17, 2021 | 12:40 PM
The search term is "gas tank braces". Don't be surprised if you need a trunk floor also. And yes, I think your mechanic is a tad melodramatic.
https://championchevelle.com/6872-ch...c7210d47a46356
Old Jan 17, 2021 | 12:54 PM
That's not something to freak out about. Maybe don't fill the tank more than 2/3rds to save some weight there. I think it will be a large repair and time consuming, so best to plan it out.
Old Jan 17, 2021 | 02:15 PM
Thank you!
I figure it will need some repair. Hopefully just some patching. New to Oldsmobile. Are Chevelle and Cutlass parts interchangeable (I know this won’t be a blanket statement) in many cases?
yes he wanted $4k to repair and replace these brackets. Won’t be using him anymore.
Old Jan 22, 2021 | 02:21 PM
Good news
Well. Interesting finding. I just removed the rug that was pasted to the trunk floor and grinded down the floor pans.
overall pretty solid trunk floor. So the rust underneath hasn’t come through. I am not finished but found some filler. So may find some rust but the trunk floor is pretty solid.
I will finish grinding it down. Then get underneath and address the rust and treat it. I may have to see about the gas tank brackets but good news for now.
QUOTE=Kelleycougar70;1310559]I figure it will
yes he wanted $4k to repair and replace these brackets. Won’t be using him anymore.[/QUOTE]
Funkwagon455
Oct 26, 2020 08:36 AM
JoeyOldsmobile
Sep 30, 2020 06:57 AM
toymobile
Jan 24, 2017 02:21 PM
rr69ho
Apr 10, 2014 01:03 PM
crazy'boutOlds
Sep 7, 2011 07:34 PM
