Backwards Fuel Gauge!
My '57 has a fuel gauge that was replaced at one time. It works perfectly - in reverse! Full=empty, empty=Full, with accurate (backwards) readings in between.
I read something on a blog about oil pressure gauges being substituted for fuel gauges and causing this problem...? Have tested the sending unit but it seems to be OK.
Any thoughts? Thanks -
Randy,
Thanks, sorry for my extremely tardy response. I do know that the gauge was replaced at one time; apparently they fudged it with who-knows-what; lends support to the oil pressure gauge theory...I have looked everywhere but haven't been Abe to find a replacement gauge.
When I say not correct I mean the OHM value doesn't match what the sender is at full and empty. If you go to the autometer site and look at fuel gauges you'll see at least 3 different ranges for fuel gauges. Some are high ohm when full, some are low ohm when full. That is what will cause the gauge to read backwards.
