B85 Belt Molding (how to remove)
Are you wanting to remove the belt molding from the trim or remove the trim from the car? The trim is mounted to the car from the inside. You will have to lower the window lower stopper to get the window low enough to get to the screws. It has been to long since I took the rubber off the trim to remember how to take it off.
