argon gas flow meter question
Old Mar 28, 2016 | 08:17 AM
edzolz's Avatar
Anybody know if a flow meter for Nitrogen flows the same as Argon meter? The one with the ball that floats inside of the tube.
Old Mar 28, 2016 | 08:22 AM
brandon reynolds's Avatar
I dont think so they have different specific gravity. So they would not read correctly.
Old Mar 28, 2016 | 08:48 AM
edzolz's Avatar
Nitrogen has an atomic mass of 14.01 and Argon has a mass of 39.95. Does this mean the meter would read approximately 2.3 times more than if flowing Argon? The nitrogen being less weight than Argon.
Old Mar 28, 2016 | 09:31 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
NO as mentioned each is calibrated differently for each type of gas. You need an argon controller for argon. The read is not linear depending on what type of controller you have. Are you using a Brooks, Parker, Teledyne or Omega mass flow controller?? If so refer to they're literature or tech line for more specific help.
EDIT:
Scratch what I just said....Just re-read your thread. Your using a simple flow regulator. It sounds like its for Mig/Tig welding? It should work with C25 and straight argon. Your not measuring a mass just a volume of flow. It should work. Best to contact the manufacturer of the regulator or welder for more specific info as a general answer may not apply? Your local welding supply will have the right answers as well.
Old Mar 28, 2016 | 01:57 PM
edzolz's Avatar
EDIT:
Yes, I will use it for C25 for TIG and MIG also. Just wanted to know if the molecular size would be different enough to make a difference. I'll hook it up and if my tungsten turns blue, i don't have enough flow.
Old Mar 29, 2016 | 09:58 AM
Within reason flow is flow. Yes always go with a visual test run when changing gasses. Make sure the thoriaded tungsten is nice and sharp. Dont use a dirty grinding wheel to sharpen it. It will impregnates contaminates into the rod causing weld problems. Buy a dedicated rod sharpener or use a fresh wheel. You should be OK with the stock flow meter with most gas mixes. Do inquire at Miller or Lincoln just for safety as I dont know all.
Old Mar 29, 2016 | 01:07 PM
jaunty75's Avatar
Look here.
Old Mar 29, 2016 | 07:25 PM
edzolz's Avatar
Another factor is, I'm using this flow meter on C25 mix so I will just have to experiment. I'm sure 25% C02 will make a difference too.
Old Mar 30, 2016 | 05:50 AM
It shouldn't be a prob, I do the gas juggle all the time. Just dial it in until your makin bacon. The best tool Ive purchased in a while is the Miller 211. Auto-Set the dam thing and go, takes most of the guess work out of the equation. Runs a tight bead even on 120VAC.
Old Mar 30, 2016 | 06:12 AM
edzolz's Avatar
I've got a Syncrowave 250. Had it for years doing aluminum, just now needing to weld mild steel and stainless.
Old Mar 30, 2016 | 03:06 PM
SS is a pleasure I dont have the knack for aluminum.
Fear Reborn
Nov 30, 2011 03:50 PM
69442murph
Nov 12, 2011 08:45 PM
Allan R
Aug 17, 2011 02:14 PM
Shebe72
Jul 5, 2010 08:11 AM
Bobac455
May 11, 2010 07:36 AM
