Anyone in readerland do vinyl stickers?
As the title says, I need some replacement “RAM ROD 455” decals made. I had to have some paint touch up done on my passenger side fender, I have been driving around without it long enough.
This is what I’m looking to have made.
I once had a Chrysler 440 rebuilt and stroked into a 496 ( cu in). It was put in a 1965 Coronet which could have been ordered with a 426 engine which was called "Ramcharger 426". Ramcharger 426 stickers were on the valve covers on the factory option. I liked the nostalgic look so I bought reproduction stickers and took one to a local print shop and he made me up some Ramcharger 496 stickers- Didn't cost that much. I had a dozen made. Check around with a print shop, you maybe able to get some made using a Ram Rod 350 sticker as a template.
I have a vinyl cutter. If I can find the proper digital art, I can easily reproduce them.
Have you tried calling Phoenix Graphix? Generally, vinyl sticker stencils are maintained w/in a computer S/W program. You call up the program, the stencil is sent to the graphics machine where the stencil is created and you're done. Worth a call. I believe they made a RAM ROD 455 as well as the 350.
Here's the RAM ROD 350
https://phoenixgraphix.com/gm/68rr350.php
https://www.jegs.com/i/Phoenix-Graph...50WHT/10002/-1
Of course another option is to buy the RAM ROD 350, cut out the 350, have a local print shop create you the same size letter & font 455 and place the 455 below the RAM ROD pistons from the cut-out RAM ROD 350.
