Anyone know where or who makes hyd performance cams for olds 324 motor
You will get some (a little) performance gain with a high lift cam but unless the compression rate is increased not much will happen including the lope at idle. It can be done but not with just a cam, you are working with a 8 to 1 compression with small valves... Check with Tony he will have the strait information and the parts to get you where you want to be.... Tedd
If you need or would want:
I have exactly 1 set of 16 -- OEM GM Valve Lifters for the 303, 324 OLDS
application of 1949 - 1956......
Still virginal brand new in beautiful boxes!!!!!!!!!!!!!!!!!
Diego
February 22nd, 2016 11:47 PM
ominayak83
April 18th, 2013 10:55 AM
e129745
November 23rd, 2012 04:31 AM
