Another Cowl Tag ?
Old July 30th, 2021, 06:36 PM
Phoenix8990's Avatar
Another Cowl Tag ?
I am wondering if the tag gives engine size and if 2 or 4 barrel, single or dual exhaust, if it was an AC car?
Steve
Phoenix8990 is offline
Old July 30th, 2021, 08:20 PM
Oldsdruid
rocketraider's Avatar
The body tag is concerned with what the Fisher Body plant had to do to accommodate the car's options. It doesn't reference engine/exhaust/driveline but some years it does indicate A/C with C60 or C61. Same as some years indicate vinyl top with C08.
Yours decodes as
69- 1969
3- Olds
36- Cutlass V8
67- convertible
LANXXXXXXX Lansing plant sequence
942- green bench seat interior
59- Meadow Green metallic paint
B- black convertible top (may be white depending on what the 69 default color was)
11B- built 2nd week November 1968
rocketraider is offline
Old July 30th, 2021, 08:35 PM
Randy C.
rcorrigan5's Avatar
Nothing specific on carburetor or exhaust. Here's the breakdown.
69 33667: Model year 1969 (69), Oldsmobile (3) Cutlass V8 (36) convertible (67). The original engine would be 350cid and the 350 came in various configurations. The 350 2-bbl 250hp was standard (Cutlass, Cutlass S) with options that included the 310hp 4-bbl carb (Cutlass, Cutlass S) or the W31 (Cutlass S) with 325hp and a 4-bbl carb.
LAN: assembly plant = Lansing MI
181145 BDY = Fisher body number (no relationship to the VIN)
942 = interior color and front seat type = green interior with a bench seat
59 B: lower body color (59) = meadow green and convertible top color (B) = black
11B = time build code = November (11), second week of that month (B), 1968
Randy C.
rcorrigan5 is offline
Old July 30th, 2021, 10:27 PM
Yours decodes as
69- 1969
3- Olds
36- Cutlass V8
67- convertible
Huge props to you Rocketraider and all like you. It is valuable and appreciated for so many of us with your knowledge and break down of body tags etc. It so does not go un-noticed. Thank you
no1oldsfan is offline
Old July 30th, 2021, 10:39 PM
Oldsdruid
Many here know as much or more than I do (see Randy Corrigan's post above) but thank you. Guess buying all these parts books, shop books and other references was worth it after all!
Old July 30th, 2021, 10:42 PM
Seriously though. Your information and knowledge helps all of us. So Thank You.
Old July 31st, 2021, 05:35 AM
It occurred to me afterwards that option are probably shown on the broadcast card?
Steve
Old July 31st, 2021, 07:58 AM
Oldsdruid
Correct. But don't expect to find one in a Lansing car.
Bad as I hate to say it, Ford and Chrysler body tags were light-years ahead of GM's for car information. Ford's parts numbering system was better too.
Old July 31st, 2021, 08:28 AM
Randy C.
rcorrigan5's Avatar
I'm not sure if a broadcast card would show the engine option or not. A build sheet would show it but, like rocketraider said, finding a build sheet in a Lansing car is virtually impossible.
Randy C.
72 Post
July 8th, 2021 06:08 AM
Adam Michael
April 30th, 2021 08:30 AM
72455
January 19th, 2019 06:39 AM
chrisneu68olds
May 10th, 2017 09:46 PM
70sdream
May 9th, 2016 04:16 PM
Quick Reply: Another Cowl Tag ?
