Alternator bracket interchange
I'd say if it looks approximately like your broken one, it's right.
You found one via that thread, right?
There's the RH mount no-AC iron/steel bracket set, then LH mount steel brackets for with AC, then the G-body era set you have, which almost always have AC therefore LH mtd alternator. There are not a lot of different ones.
Possible exceptions: Toronado engines, and Pontiac 403 applications.
Any LH side AL bracket from the Olds car Olds V8 engine of the 78+ era should do for you.
442mark
Sep 30, 2017 01:06 PM
xerxes600rr
Aug 30, 2011 06:43 AM
