Air conditioner leaking oil
Old Jul 11, 2025 | 04:06 PM
Horsepower's Avatar
So after a complete restoration on my 72 Cutlass I recharged the ac it cooled very nice. The next day I noticed an oil spot on my shop floor. I put the car on my lift it was leaking out of the condensation drain at the bottom of the evaporator box . After several days of sitting it stopped leaking and now the ac doesn't cool any more. Any thoughts?
Old Jul 11, 2025 | 04:36 PM
Sugar Bear's Avatar
Sounds like the evaporator core is leaking. Maybe you'll get lucky and a connection was left loose or an O-ring was left out.
Old Jul 12, 2025 | 04:30 PM
mister442's Avatar
I would agree with the leaking evaporator core, On my 1970 Rallye it was the core due to the wrong self tapping bolt used for the inner heater/ a/c box and it went into the top of the evap core.
Old Jul 12, 2025 | 04:47 PM
Horsepower's Avatar
That's what I thought sounds like a good winter project. I'll be looking for a good used evaporator coil.
Old Jul 12, 2025 | 05:20 PM
Sugar Bear's Avatar
With refrigerant lines disconnected the core could be isolated and vacuum tested for leaks in place before removal.
Old Jul 12, 2025 | 05:35 PM
My '71 CS was leaking exact same spot. I replaced w/ a new core. New evaporator cores are readily available.
Old Jul 12, 2025 | 05:50 PM
79cut's Avatar
Replace evaporator and test with nitrogen the fittings on the new one
if no bubbles pull vaccum and recharge
Old Jul 12, 2025 | 05:52 PM
79cut's Avatar
connections are outside of the drain pan
so it wouldn’t be leaking out if the drain pan
Old Jul 12, 2025 | 08:15 PM
Horsepower's Avatar
It's not a connection for sure.
That's a good idea to isolate it and test it. I think I'll do that.
Old Jul 12, 2025 | 09:43 PM
79cut's Avatar
you know it’s leaking. Unless you are a really good aluminum welder you ain’t fixing it
just get a new one. They are not that expensive
Old Jul 13, 2025 | 12:31 PM
mister442's Avatar
The Parts Place has real GM evap cores for 220 bucks, thats where I got mine.
Old Jul 13, 2025 | 01:01 PM
Horsepower's Avatar
Thanks mister.
Old Jul 13, 2025 | 01:05 PM
I've purchased many products from Old Air Products to include the new evaporator core. Extremely satisfied w/ their workmanship, service & support.
https://www.oldairproducts.com/produ...aporator-coil-
Old Jul 14, 2025 | 12:38 PM
Hammerdrop's Avatar
Make sure you add oil to the system.
FStanley
Nov 18, 2023 08:37 PM
BSiegPaint
Jul 24, 2022 03:21 PM
oldspackrat
Jun 8, 2013 12:30 PM
69442C
Apr 30, 2011 02:02 PM
71cutty
Feb 23, 2010 10:18 PM
