air compressor
Old Oct 28, 2013 | 02:10 PM
charlierogers's Avatar
air compressor
just picked up a Ingersoll rand air compressor 7.5 hp 80 gallon upright 2 stage on the cheap. I am thinking of installing it out {next to} of my garage in a shed that is right against the garage that is not heated. this will clear some floor space and help with the noise. has anybody here done something similar? any thoughts or advise?
thanks Charlie,,,
Old Oct 28, 2013 | 02:28 PM
stan 65 cutlass's Avatar
good way to go, just be carefull if its below freezing
Old Oct 28, 2013 | 02:41 PM
well I am in Illinois, I figure my old compressor sat in the garage with no heat plenty of times with temps well below 25 degrees with no problems. maybe just keep an eye on things when using it and check/drain water from tank when done? I figured I could put a small fresh air intake with motor for summer time to keep from overheating if necessary?
Old Oct 28, 2013 | 03:00 PM
citcapp's Avatar
I sure hope it is a 230 volt single phase motor and not a 3 phase motor. That being said a 7.5 hp motor single phase motor will drae 40 amps at 230 volts single phase and will need to be fed with an 80 amp breaker to handle the starting load along with a manual starter with overloads to protect the motor. #8 wire will work for your installation. They are great compressors and should live a long life
Old Oct 28, 2013 | 03:05 PM
We've had a compressor out in the garage for the past 30 years in NY, never had a problem, have run it on 10° days plenty of times.
I wouldn't sweat it, but it's probably better not to run it for long periods way below freezing, as condensation would freeze and be hard to drain (the heat from the compressor should prevent freezing problems in the pump itself).
Old Oct 28, 2013 | 04:25 PM
yes it is 230v single phase, I have 100 amp service to garage so I am covered there. eric, thanks for the input!
Old Oct 28, 2013 | 04:53 PM
I put compressors outside for years with absolutely no issues.
Old Oct 28, 2013 | 05:17 PM
Sampson's Avatar
I sell industrial A/C. I see them outside all the time. Most of the time they just have a shed roof over them. Just make sure you drain the tank to get the water out and you will be fine.
1983oldsmobiledelta
Nov 18, 2010 12:38 PM
lil_no
Jan 14, 2010 01:19 PM
Hairy Olds
Jul 12, 2009 09:21 AM
1FSTLS1
Dec 28, 2007 07:45 PM
jaco
Jan 5, 2007 08:57 PM
