Air cleaner id
It looks like a Pontiac dual snorkel air cleaner base that has had the snorkels cut off just inboard of the Thermac vacuum actuators and has had a repro Ford rubber seal added to the rim.
The stock Pontiac air cleaner looks like this (note the angle of the snorkels):
The Ford rubber seal looks like this:
It looks like this was an attempt to fabricate a clone of a Camaro dual snorkel air cleaner base, but you'll note that the real Camaro base has the snorkels at a different angle and the ends are flared, not straight cut.
I agree the GTO is close, but this one heavily clearance on the passenger side underneath, also there is something protruding inside on the drivers side, could be aftermarket,here's the ad.
https://losangeles.craigslist.org/sf...314173160.html
