Aftermarket Fog light issue
Old Oct 7, 2017 | 06:26 PM
Oldssupreme's Avatar
Chris
Hello. I have installed an aftermarket fog light kit in my 2009 Nissan Xterra. I have installed everything except for the power wire to the switch which is supposed to be connected to the ignition wire but I really don't want to splice into the factory wiring. The fog lights don't work without this wire connected to a power source. If I connect this power lead directly to the battery the fog lights work fine and the backlight of the switch lights up but stays on even after the switch is turned off and the key is taken out of the ignition. Obviously this is not an option as it would drain the battery. How would I allow this to work properly with the backlight going off when I remove the key or turn the off the switch? ? Can I place this power wire in the fuse of the "illumination" slot or would that only allow the fog lights to come on if I turned the headlights on? I'd want the fog lights to come on by themselves. I figure I could wire in a switch immediately before the fog light switch (if I wired the switch directly to the battery) but then I'd have to remember to turn off that switch. How can I properly do this without splicing into the ignition wire? Any other fuses or relays I can tap into to make this work properly? Thanks so much!
Chris
Old Oct 7, 2017 | 06:36 PM
If you can't make the switch indicator light work only when the switch is on, you can change the switch to one without an indicator light or you can run fog light switch off the IGN terminal in your fuse block and have it trigger a relay to power the fog light circuit.
Old Oct 7, 2017 | 06:51 PM
Chris
Eric thank you for your reply. How Exactly do I connect to the ignition fuse block? Do I take the fuse out and wrap the wire around it? Actually if I recall it might be a relay in the block and not a simple fuse. Would it matter either way? Can I still Wrap the wire around the relay and reinstall if that's what it is? There is a relay between the battery and the fog lights but would that relay be sufficient? Thanks!
Old Oct 7, 2017 | 07:25 PM
Chris
I have attached photos of my fuse block diagram. Which one would you attach the switch power wire to?
thanks!
chris
Old Oct 7, 2017 | 09:02 PM
Mike77's Avatar
You simply have the power connected to the wrong side of the N/O contact. It is powering the lite constantly. You want it so the switch lite is only on when the fog lite are on.
Old Oct 8, 2017 | 03:24 AM
You have a fuse in there marked fog lights, is there a fuse in the slot? My brain went back to an old Olds fuse block, sorry for the IGN reference.
Old Oct 8, 2017 | 04:52 AM
Chris
Thanks guys. There is a fuse in the fog light slot. However the original fog lights would have been run off of the stalk which I don't have. Does that matter or can I still use this fuse regardless? I guess power would be flowing through that fuse whether or not the optional stalk switch existed.
chris
Old Oct 8, 2017 | 04:57 AM
Chris
And Mike, what is the N/O contact?
Thanks!
Old Oct 8, 2017 | 05:27 AM
chris
I would assume so, there would also be a wire under the dash thats powered by it.
Thanks!
N/O = normally open
Old Oct 19, 2017 | 04:42 PM
Chris
Ok. So I'm still having issues. I tried using a fuse tap and tapped into the radio fuse, the heated mirror fuse, and several others which turn off with the key and the backlight would still not turn off. The fog lights work, but Just the backlight issue. I have not tried the ignition fuse although I'm not sure that would make a difference. Thoughts? Can I get into this switch to remove the light bulb or are they sealed? Thanks guys!
chris
Old Oct 19, 2017 | 08:15 PM
Can you post a picture of your switch, front and back?
Old Oct 20, 2017 | 04:09 AM
rustyroger's Avatar
'87 Delta 88 Royale
Is it front or rear fog lights you want to fit?.
Most markets where Nissans sell rear fog lights are mandatory. It could be the wiring is all there, just needing a switch and rearlight cluster.
Roger.
Old Oct 21, 2017 | 04:18 AM
Chris
These are the front fog lights in the bumper. I just don't understand why, if I am tapping into a circuit that normally goes off when the key is out, why is my switch backlight still on even if the original accessory is off?
My cutlass is much easier to figure out lol.
Old Oct 21, 2017 | 04:57 PM
Chris
Mike, I looked at your post again and if I post a pic of the switch wiring would you be able to explain how I can wire it so that he switch light is only on when the fog lights are on? There are two lights in the switch. One is on only when the lights are on and the other backlights the whole switch. And what contact is the "normally open" contact? Are you referering to the switch?
Thanks!
Old Oct 21, 2017 | 05:30 PM
Yes, post a pic of the wiring diagram. A pic of the switch may help also.
Oldsr4me
Oct 15, 2016 05:16 PM
NINETY_EIGHT_REGENCY
May 18, 2014 07:12 PM
navvet
Nov 11, 2013 04:10 PM
BeenThere
Feb 21, 2013 10:42 AM
pblack
Aug 15, 2008 02:52 PM
