aftermarket carb with oai
Old Jul 30, 2017 | 06:23 PM
truckman5000's Avatar
W30
My quadrajet carb was on its last leg months ago. Its been sent out to be built, still being a pain. Ive driven the car 50 miles since.
Now I just went through it, again. The issue is it over fuels....Is it really true the quad. carbs are the best? Ive had 2- mechanics "look at it"
The carbs an original w-30 auto carb, but its a Frankenstein thing, some one I think drilled stuff out or widened chambers ...
Anyways I was going to get a Jet rebuilt carb, but their weeks out.
Does an edelbrock carb fit with the oai cleaner?
Is there a quick solution?
I know the correct answer but dont want to loose another year not able to drive the dam thing.
Old Jul 30, 2017 | 06:47 PM
You can get a core Rochester and rebuild it or you can get a rebuilt one and put yours on the shelf until you can get it fixed.
Old Jul 30, 2017 | 06:54 PM
W30
[QUOTE=oldcutlass;1033274]You can get a core Rochester and rebuild it or you can get a rebuilt one and put yours on the shelf until you can get it fixed.[/QUOT
I was looking at the demon made b
y holley, that is a spreadbore. But idk. If it would fit the oai . Base plate.
I dont think a retrofit will fit?. It is best to stick with the q_ jet?. Probably
Old Jul 30, 2017 | 07:03 PM
Not familiar with the Demon. Don't get an Edelbrock the air cleaner may not work with the fuel line and choke setup.
Old Jul 30, 2017 | 07:11 PM
W30
thanks, seems like the q.jets the way to go. With fitment
Old Jul 30, 2017 | 07:12 PM
11971four4two's Avatar
MOTORHEAD
carbon
I run quadrajet on my 4bbl cars
the mid 1970's big block units flow 800 cfm
the earlier ones can be good options too
Old Jul 30, 2017 | 07:15 PM
toymobile's Avatar
I have a Q J that worked good when removed 3 years ago 750 CFM, $50.00 shipped to MA.
Let me know. Thanks
Johnny
442KoneKilr
Mar 17, 2016 08:12 PM
sx455raidercelticfan
Dec 21, 2010 05:19 PM
Dave Siltman
Dec 12, 2010 03:59 PM
Oct 18, 2010 07:26 PM
GoldOlds
Jul 22, 2007 08:26 PM
