Advice needed
Old Aug 12, 2018 | 12:58 PM
Rvsmith5's Avatar
Advice needed
While putting my upper control arms back I got the nut on one of these brand new bolts seized so tight even my impact could not back it off. Ended up cutting it in half. In the process I stripped the knurls inside the frame. Should I order new ones and just hold both ends to torque, or just replace with grade 8 at this point?
I got it this far, went from typical lock washer resistance to locked in about half a turn.
Old Aug 12, 2018 | 01:33 PM
If the bolt can spin, it makes it more difficult for the alignment guy to loosen/tighten the nut to install/remove shims..
Old Aug 12, 2018 | 03:02 PM
It may be inconvenient for the alignment guy but it will work.
Old Aug 12, 2018 | 03:12 PM
Rvsmith5's Avatar
Would it be better to get new knurled bolts and then tack it in place when its all done?
Old Aug 12, 2018 | 05:02 PM
You can tack the GR8 in place.
Old Aug 12, 2018 | 06:58 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Cut it, drift out the stud and replace it. It's really easy to do. The Vette venders sell the correct knurled stud n nut. Fusick, Year One, OPG may sell it too.
foo
Suspension & Handling
Oct 28, 2012 07:01 AM
Tony72Cutlass'S'
Jul 9, 2012 12:08 PM
Lady72nRob71
25
Apr 3, 2012 05:26 PM
garys 68
Apr 27, 2011 05:13 AM
Redog
Nov 30, 2007 11:55 AM
