Adding power steering to 1949 98
Old Sep 3, 2020 | 11:00 AM
Love1955oldsmobile's Avatar
I am going to add power steering to my otherwise stock 1949 98. I am thinking of a pancake power steering pump setup like the bowties of the sixties. Any guidance? Comments good bad and ugly? Anyone made this alteration? If so pictures and pitfalls? Thanks. Ron
Old Sep 3, 2020 | 02:43 PM
coldwar's Avatar
Your 98 is a C body Oldsmobile, body construction by Fleetwood. I'm mostly sure the steeering box and mast jacket assy's will bolt in from years 1952-53, which are Fisher body cars. The 1953 mast jacket and steering are overall shorter then earlier years, meaning the wheel is now closer to dashboard. Also, 1953 does not have a shift quadrant on mast jacket, in that year shift indication is in instrument cluster. So 1952 is the one if you want factory bolt-in stuff.
Another problem is the steering pump with factory brackets uses some of the attachment points used presently by generator. With power steering in 1952, generator was moved to passenger side of engine attached to exhaust manifold, then with no idler pulley for generator belt tension. Not a lot of room in the earlier years as the wheel well is right there at the front passenger side corner of engine. This all assumes the use of GM Oldsmobile parts.
Factory Oldsmobile power steering parts are sought after today, but with some looking money and patience you might find what you need. It's a great, easy to drive system with one finger control even at idle. Good luck ~
Old Sep 3, 2020 | 02:57 PM
coldwar's Avatar
"....Thrill to the new Rocket ride as you cruise at high speed past architecturally significant residences in the Culver City area...."
Old Sep 3, 2020 | 03:42 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Seems funny they used blackwall tires in the commercial.
Old Sep 4, 2020 | 05:17 AM
rocketraider's Avatar
Oldsdruid
Gotta remember in 1952 we were barely out of the Korean "police action" and chrome and rubber were still tough to get. But yeah, whitewalls would have set that S88 off.
69Chrgr
Oct 16, 2019 12:40 PM
larryejoh
May 20, 2019 05:48 AM
rpinnt
Jul 20, 2018 10:49 PM
edzolz
Apr 22, 2018 03:42 PM
Fletch
Sep 28, 2009 04:52 PM
