Add AC & Power Steering
Old Jul 27, 2017 | 06:12 PM
Lsx442's Avatar
Question Add AC & Power Steering
My 69 442 was born without ac or power steering and when it was restored it was put back to the way it rolls off the assembly line.
I'd like to add AC and PS to the car. Can someone tell me what all I'll need to get to make this happen? I know I'll need pulleys and brackets but I'm not sure where to start looking.
Old Jul 27, 2017 | 06:39 PM
70sgeek's Avatar
'72 Cutlass ragtop
if you have a factory non-AC car you'll essentially need to start from scratch with an aftermarket retro-fit system such as Classic Auto Air or Vintage Air - factory AC firewall and duct work is different from non-AC and original equipment won't readily interchange. Expect $$$$ investment
as to adding power steering, that's much simpler. you need the pump bracket, mounting hardware, proper groove pulleys for pump and crank, correct pitman arm, rag joint, your choice of factory-fit pumps, proper pressure hose and return line and steering gears (many sources available for these, both remanufactured originals and new higher performance items). this is a fairly cheap upgrade depending on what you decide on for pump and gearbox.
Steering parts are standard A-body stuff, same for all 68-72 GM - available thru any decent auto parts store. ebay, numerous online vendors, board members, etc. If you want a great, complete direct-replacement kit (less bracket), check the CPP (classic performance parts) website for their 500 series kit.
http://www.classicperform.com/Store/...o/CPP68PSK.htm
you can buy the p/s parts in kit form (with new or remanufactured pump/gearbox units) with everything included, possibly even with the correct brackets (but if not, many board members will likely have them available for sale).
Old Jul 27, 2017 | 07:16 PM
toymobile's Avatar
I have most of the PS & Alt brackets, The pump has the wrong pulley but the pump and brackets are right. Let me know, Thanks
Johnny
Old Jul 28, 2017 | 07:59 AM
Power steering is easy. Retrofit of the stock A/C pretty much requires disassembly of the car. Front end sheet metal has to come off, dash has to come off, etc. The only cost effective way to do this is to purchase a complete A/C parts car.
Old Jul 28, 2017 | 09:20 AM
Don R.'s Avatar
MANY years ago I did the factory A/C retrofit on a 69 Cutlass. I used a 68 Cutlass as a donor and just swapped everything car to car. As I recall the only firewall issue was enlarging some openings, having the donor car sitting there is a major help. I replaced the compressor and expansion valve and paid to get it evacuated and charged, it worked fine. Today you would have to think about R-134 conversion and probably replace more parts to be safe.
Old Jul 28, 2017 | 09:32 AM
Correct. The A/C openings in the firewall encompass the heater-only openings, so you can simply cut them larger. The problem is pulling all the front sheet metal and the dash to get access.
Old Jul 28, 2017 | 09:43 AM
Lsx442's Avatar
Would a Vintage Air or similar kit be easier than sourcing all of the OE parts? It seems like for ~$1500 I can get a VintageAir system. I think I still provide my own crank pulley
Old Jul 28, 2017 | 09:48 AM
If all you want is to add A/C, an under-dash unit is even easier and less expensive.
Old Jul 28, 2017 | 11:17 AM
Lsx442's Avatar
Joe I hadn't thought of that system but I will look into it. I had a friend with an F100 with a kit like that and it seemed to work really well.
Driving in this 100 degree weather without ac is tough. I don't know how I did it when I was youngster
Just a follow up question a will AC & PS brackets from a 77 Olds 350 motor work on my 69 400?
fennjones
Jan 30, 2015 12:58 PM
nicks1966
Jan 12, 2014 01:46 PM
Keieljun
Suspension & Handling
Feb 5, 2009 09:27 PM
gearheads78
Sep 15, 2008 10:01 AM
pearldawg23
Feb 14, 2008 05:08 AM
