72 olds 442 speed ques
I have a problem where the speed is running 5 miles an hour to fast I have 323 posi rear and a th400 tranny.Had one of my freinds drive a long side of me and found out it was running to high.the car originally had a 350 engine know has a 455ci motor but not sure of the origanal tranny the odometer reads 27,250 which I think had originally 127,250 miles on it
could have a different speedometer gear or driven gear in the trans now for the rear end that is in there. You need to find out the code on the rear end and then check where the speedometer cable connects to the trany - there should be some numbers on the shaft like 40,41,42 that will tell you what spedo gear the transmission is set up for.
