72 Cutlass Rims / Wheels width ?
Old May 21, 2018 | 08:34 AM
JCervantes's Avatar
Question 72 Cutlass Rims / Wheels width ?
Can I run 15 x 8" SSII's all the way around or will I run into issues on the front ?
I currently have 245/60/14's all the way around on what appears to be 7: alum slots (Hard to measure with tires installed)
Old May 21, 2018 | 09:56 AM
droptopron's Avatar
delete
People have done it but a lot of it will depend on how your car sits. Health of the springs (stance) will matter.
Old May 21, 2018 | 01:09 PM
JCervantes's Avatar
Thanks, I was thinking if I kept to the 245/60R15 (Same size as the 14's but now a 15") I would be Ok. It sounds like what you are saying is the rim should not be an issue.
Old May 21, 2018 | 01:43 PM
dc2x4drvr's Avatar
Depends on front wheel back spacing, I ran 15x8’s with 275-60’s on steelies on the rear, and 235-60’s on the front on 15x7’s, and the fronts rubbed the swaybar in a tight turn. This was when I ran stock springs.
Old May 21, 2018 | 04:44 PM
anthonyP's Avatar
Which 15x8 reproduction SS-1 wheel is correct, or better, for the rear of a '70 Cutlass - the model with a 5" backspace or 4 1/2" backspace? The 15x7 SS-1 wheel only comes with a 4.375" backspace .
Old May 21, 2018 | 06:17 PM
dc2x4drvr's Avatar
IIRC, 4 1/2” is stock BS, 4.375 is close enough depending on tire size
Old May 21, 2018 | 06:39 PM
anthonyP's Avatar
Do you know if the 4.375 backspace will work on the front with 235/70-15 tires?
Old May 22, 2018 | 04:49 AM
Sampson's Avatar
I am running 8" SS 1's purchased from Summit with 295/50R15 on the rear and 255/60R15 on the front. I cannot remember for sure but I think the wheels are made by Wheel Vintiques. I had some minor clearance issues on the front and trimmed a little off the left front fender wheel lip. I will probably step down a size when I replace the front.
Old May 22, 2018 | 06:43 AM
droptopron's Avatar
delete
That's a really tall front tire. I think most people who run a 70 series go 215 or 225
Old May 22, 2018 | 09:45 AM
JCervantes's Avatar
72 Cutlass wheel width
Sampson,
So you are saying you are running 8" on all 4 ? I want to make sure before I buy $400 in rims and find out they don't work.
Last edited by JCervantes; May 22, 2018 at 09:47 AM. Reason: directing towards Sampson
Old May 22, 2018 | 05:52 PM
Sampson's Avatar
Yes I am running
15x8 all the way around. Not sure on the backspacing. The 255r 60 is a little tall. I also have disc brakes on front. Not sure if that makes a difference. I like the deep dish look.
Old May 23, 2018 | 07:24 AM
JCervantes's Avatar
Thanks Sampson !! I also like that deep dish look, I'm going for it
Old May 23, 2018 | 09:15 AM
JCervantes's Avatar
Sure I just talked to the guy, Now he wants to know what backspacing I need. I'm not a rim guru at all, Completely at a loss .... Can anyone help ? I want them to look good like Sampsons and not rub.
Old May 23, 2018 | 09:23 AM
JCervantes's Avatar
So He said 4.5 backspacing is standard, BUT there is a risk of some inside tire rub on tight turns against frame or sway bar ... What to do what to do ....
Old May 23, 2018 | 05:54 PM
Sampson's Avatar
I dug out the receipt from when I ordered mine. The back spacing is 4.5". Here is the link. https://www.jegs.com/i/Wheel-Vintiqu...34042/10002/-1
All I can add is I do not have any problems with tire rubbing on the frame or swaybar. I did have a minor issue with the left front fender on sharp turns in reverse. i trimmed it a bit and no problems since. As others stated spring height and condition plus tire size may come into play.
Good luck and I hope this helps.
Steve
Old May 23, 2018 | 05:59 PM
Sampson's Avatar
Great looking Cars! Love the Anson Slots.
Old May 23, 2018 | 06:08 PM
dc2x4drvr's Avatar
Sampson’s car is gorgeous, and looks like it sits kinda high, keep that in mind, I would run 245’s on the front, should be safe with 15x8’s..
Just my .02
Old May 23, 2018 | 06:19 PM
anthonyP's Avatar
Does anyone know if 235/70-15 tires on 15x7 wheels will fit in the front without rubbing on a '70 442?
Old May 23, 2018 | 06:28 PM
dc2x4drvr's Avatar
I ran 235-60’s on 15x7’s, had minor rubbing on my big sway bar, I think you’re good to go..70 series are slightly narrower.
Old May 23, 2018 | 07:08 PM
Actually, the 70 series are the same width but taller.
Old May 24, 2018 | 07:15 PM
anthonyP's Avatar
Will there be a problem with the height of 235/70-15 tires in the front of a '70 442?
Old May 26, 2018 | 06:59 PM
droptopron's Avatar
delete
Hard to say on a 50 yr old car
For example, Sampson's car look a little in in the front
ah64pilot
Jul 5, 2012 06:51 AM
1971442clone
Feb 11, 2010 06:48 PM
84hurst
Hurst/Olds
Jan 22, 2010 07:52 PM
stlbluesbrother
Dec 24, 2009 05:47 AM
