72 Cutlass Grill
Pretty sure yours should say "Cutlass Supreme"
The Cutlass 'S' Grilles said "Oldsmobile" in 1971. Had 3 long studs in back.
Also, that's a 1971 Grill, not correct for your 1972 Cutlass model. But it fits just fine.
ALL 72 CS grills look like this (with the the exception of the 442 style grills):
442 style:
Tony, you might have got fooled on that photo you posted because of the stone shield rocket? Don't forget that in 71 the background color of the paint (black in this case) showcases the rocket really nicely making it look like 72. But the grills are 71, and the headlight bezels are also all silver - traits of 71. The 72 has blacked out headlight grills too, remember?
Also note: 72 CS only has OLDSMOBILE in the script on the front grills, not Cutlass Supreme. Only place you find the Cutlass Supreme Script on a 72 is: a) glove box door, b) C/S emblem on the sail panels. Even the side fender only has a Cutlass emblem.
EDIT: webby - that stone shield rocket you have is also for 71. See explanation ^^^
The Cutlass S could also be ordered with the 442 appearance package (W29) or the W30 performance package, both of which would use the grills I posted earlier. Only difference in cosmetic appearance is the 442 didn't have rocker stainless trim. I see your car doesn't have that or the wheel opening moldings either. Did you remove them? Curious - is that an OEM hood, and by any chance did your car come with a U code 455? I notice it has the dual exhaust trumpets at the back.....
You think YOU missed something. I feel like a total moron now.....
Well I'm learning a lot. I bought the car in January of this year, and it came with that grill. Didn't do my home work, title says "72", was told it had a 455, but the number on the engine says its a 425. From what I've researched the 425 was available for a couple of years around 67....Serial # says 3F87H2R. Didn't come with wheel opening moldings either. I'm sure the hood isn't original either. What's that tell us? Thanks for the info.
Steve
Steve
Steve
Steve
the info you provided tells me the car was originally built as an (f85) 2 door Cutlass, had a 350 2 bbl carb, and was built in Arlington TX. It looks like someone upgraded the interior trim when they were 'building' the car. The base Cutlass did not have rocker chrome, but it did have wheel opening moldings. You can probably see where the screw holes are if you look. It's still a very nice looking car.
The 425 was indeed from 65 - 67. The casting on the 425 block will tell us whether it was an early production or later. 386525A was early. The 66/67 production was 389244D
Regardless of what it was in the past, bottom line is I hope you enjoy driving it!
Allan,
I appreciate all the information. Think it would be wise to put a "72" Grill in it and the correct script along with wheel opening moldings? Then sell the 71 grill? The 425 runs really well and has the late production number, but even growing up, I was unfamiliar with the 425 and don't know anything about it.
Steve
Steve
It really depends on what you want out of the car Steve. Cutlass S grills are not repopped so if you wanted them, you would have to search the web. The 442 grills however are repopped but do have some fitment issues. They would look nice in that car, especially with the OAI hood. If you decide to replace them, I would keep the stoneguard (plastic center piece) and just replace the grills/rocket. You can also find opening moldings on line for reasonable pricing if you want to install them. If it was me, I'd want a 72 car to look like a 72 car all the way around; but that's just me.
What plans did you have for the car?
BTW if the 425 is working for you, just keep driving it.
Steve
Steve
What it tells me is you have a sweet ride and don't have to worry about every last little detail being factory correct. Pick whatever grilles and emblems that you like and have fun.
71 grill
Hey Webby:
I'm needing for a pass side grille for a '71 supreme (already have driver side). If you're thinking of making the switch to '72 grills, I would be interested in your '71 grill for the passenger side.
