72 CS glove box light
Old Feb 2, 2020 | 05:22 PM
yellowone's Avatar
Can anyone shoot me a picture of the proper mounting of the glove box light? Thanks all.
Old Feb 3, 2020 | 06:56 AM
oddball's Avatar
Bulb goes up so it shines through the plastic, screw goes up into metal dash, bulb on the inside of the screw.
Wire it up but leave it hanging. Then install the glovebox liner. Once the liner is in place it's pretty obvious - there's a notch for it.
Old Feb 3, 2020 | 12:24 PM
yellowone's Avatar
I found my light tucked in behind the glove box. Here are pics of it. Looks like it has been painted. If the bulb faces UP then mine will never work, but the plastic has a small bend in it so it tilts up or down depending on how you mount it. That is why I asked which way is which.
Old Feb 3, 2020 | 01:00 PM
Edit: I checked my car this evening and the glove box lamp is painted black like yours, so I don't know what I was remembering.
I noticed years ago that some are painted and others are not. Both my '70 and '71 had non-painted lenses, so I'm thinking the '72 lenses were painted, but I have no data to verify that.
Old Feb 3, 2020 | 02:22 PM
yellowone's Avatar
So if the bulb goes up, there is no way for light to shine down into the box. So should I scrape off the paint and hope there is enough translucency remaining to illuminate the glove box.
Old Feb 3, 2020 | 02:52 PM
I found this thread with pictures. Hope it helps:
https://classicoldsmobile.com/forums...ck-how-122157/
I looked at mine this evening and it is mounted the same as in the post above. The black painted surfaces are to block the light from shining into your eyes at night.
Old Feb 4, 2020 | 07:07 AM
oddball's Avatar
It's supposed to be painted like that. And yes, it still works. The bulbs are super bright, so the opaque plastic and paint turn it from a blinding glare into a soft glow.
first442
Feb 15, 2019 07:35 PM
Eastflorida
Jul 7, 2017 05:10 PM
kansjfr
Jan 17, 2015 12:54 AM
kansjfr
Dec 20, 2014 12:24 AM
kevinkpk
Nov 4, 2007 03:26 PM
