71 cutlass with removable hardtop
You buy the car and we will find out. Joe i can't see how that would effect doors at all. Care to shed some light on this please.
Convertible frames are boxed to make up for the loss of stiffness when the roof is cut off. Hardtop frames are not boxed. Cut the roof off a hardtop and it will eventually sag and twist. Door fitment is one of the first things to go.
What i am getting at nay sayers is all of Joe's concerns could be addressed without a convertable frame. Boxing a frame isn't that hard and adding supports. I guess what i am saying is it could be done if the right guy did it.
Of course it could, though it would be even easier to just swap in a convert frame. Every time I've ever seen one of these "cut the roof off" cars, however, no work has ever been done to reinforce the frame.
Only way I would do it is to start with a convertible and a donor hardtop shell, and even then it would be dicey.
One of the neatest things about the 70s C3 Corvettes, maybe other years too, is that they had a properly designed hardtop that would be an accessory to the convertible and it would use the convertible attachment points on the windshield frame and the two latches on the back deck.
Years ago, Bryceman (442.com founder) had a picture of a Sienna '71 Supreme that he owned on 442.com with the top newly cut like that, but the car was fully intact and did not have any white paint on it. His car was in Kansas if I recall correctly, so it could be the same car. Looked a lot better then.
Terry
Terry
I almost bought a car like this one. I had it on a short list during a road trip to pick up another Cutlass. I figured if the deal fell through on the car I was after I would buy the frankenstein convertible. Both were destined to be donor cars.
2blu442
January 13th, 2013 05:19 PM
