71 and 72 W-30 1/4 mile time
Old Aug 29, 2022 | 06:46 PM
jensenracing77's Avatar
What was the reported 1/4 mile time for the 71 and 72 W-30 off the show room floor with stock tires and all? I can't seam to find this in the old magazines?
Old Aug 29, 2022 | 08:51 PM
69CSHC's Avatar
Originally Posted by 69CSHC
Here is High Performance Cars November 1972 test result for the 1972 W30 AT, PS, PB, no A/C. 3.42 gears, G70-14 Tires. 14.37 @ 98 MPH
http://wildaboutcarsonline.com/membe...0_Test_1-4.pdf
Sorry don't have the 71s specs handy... But here is the legendary 1970 W30s specs.
1970 W30
In the May 1970 issue, High Performance Cars tested that yellow 70 with the red stripes. AT, W27 rear, PS, PB, but no A/C. 3.42 gears, stock F70-14 bias ply tires. They ran a best of 14.30 @ 98 MPH.
Old Aug 29, 2022 | 09:06 PM
69CSHC's Avatar
1971 W30
Old Aug 30, 2022 | 02:42 AM
fleming442's Avatar
Blistering
Old Aug 30, 2022 | 05:48 AM
The problem with period magazine tests is that they are not normalized for driver skill, weather, or traction. I remember Motor Trend pointing out that they do not power shift, whereas Hot Rod and Car Craft did. And also, you need to pay close attention to the equipment like gearing. Super Stock magazine tested a 1972 W30 (AT car with the lame cam, power brakes, no A/C, 3.42 gears, and stock Uniroyal bias ply tires) and turned a best of 14.47 @ 100.34 MPH. That was manually shifting at 6000 RPM (with the base shifter, not a Dual Gate) but they did not indicate if they power braked for launch or not.
Old Aug 30, 2022 | 10:07 AM
69CSHC's Avatar
Blistering
They definitely were in their day.
I didn't mean to disparage the 70 W30 by writing legendary. What I meant to imply is the 71 and 72 are totally on par. But don't seem to get the same respect. Especially the 72 which was absolutely one of the quickest cars money could buy when released.
14@100 is muscle era quick.
W30s touched 13s when stick.
66 W30s are 12 second car's with modern traction...
Old Aug 30, 2022 | 10:27 AM
fleming442's Avatar
Stock 67 442s would go 12s on slicks. I have some of dad's timeslips, 12.89@105, IIRC.
Old Aug 30, 2022 | 04:54 PM
4R5's Avatar
4R5
I had posted a question a while back regarding the '70 vs '71 W30 performance, mentioning that I seemed to remember an article that compared the 2, specifically to understand the performamce difference due to the lower compression in the '71.
But based on the results above, it looks like the compression drop did not significanlty reduce performamce. I suspect that the lower compression would make the car more "doggy" of the line, but the mid 3's gearing would cover that up.
dc2x4drvr
May 7, 2023 09:53 AM
Vader
Sep 5, 2019 03:49 AM
Vader
Mar 30, 2019 06:22 AM
Vader
Feb 28, 2018 08:57 AM
1969w3155
Apr 22, 2012 07:49 AM
