700r4
Old Nov 18, 2013 | 05:14 PM
quentinnw2's Avatar
700r4
If I'm running 3.42 gear in a 10 bolt with 295-35-18 tires and if I go with a 700r4 tranny my motor is a 350 olds with a 520/523 lift my question will a 700 r4 be a choice to go with?
Old Nov 18, 2013 | 06:20 PM
gearhead1218's Avatar
If your original trans was a TH350, then a 200/4R will be a more direct bolt-in.
Move the crossmember back, same driveshaft, add a TV cable.
Old Nov 19, 2013 | 09:11 AM
tmaleck's Avatar
The tire size you mention is 26.13 inches in diameter. Using my gear range calculator, it says you'll be at 2156 rpm @ 70 mph. Gearing shift points may be a bit low rpm-wise, but a shift governor calibration kit will solve that. 200R4's get most of the love around here, and if my car had not come with a 700R4, I would have likely gone that way too. Since I have a 700, I figured out how to get it to run the way I want and am very happy with the results. It has a shift improver kit, re-calibrated governor, 2200 stall, hydraulic lock-up conversion and assorted internal upgrades for longer life and power handling.
Tim
TOONLOVESCHERYL
Feb 4, 2016 06:30 AM
64starfire
Jun 10, 2009 06:51 AM
projectheaven
May 18, 2009 05:20 AM
64starfire
Apr 22, 2009 01:00 PM
Jolly Green
Feb 25, 2009 07:25 AM
