70 vert...could not resist
#41
My Cutlass S has the the hood you posted Allan...72
I thought the converts came with the same hood as the CS in 70 and the louvers that ran across the hood by the cowel were for 442's and S's with AC...I am sure I read that here somewhere![Roll Eyes (Sarcastic)](https://classicoldsmobile.com/forums/images/smilies/rolleyes.gif)
![Confused](https://classicoldsmobile.com/forums/images/smilies/confused.gif)
#42
Ted, the 71 and 72 hoods were pretty much identical - except for the 42 W29 option. That one had different hydro piercings for the Oldsmobile Script on the LF above the headlight bucket.
I'm wondering if you're getting the 72 AC/non AC hoods mixed up. The 72 model year brought in hoods that had no rear vent piercings for AC cars. Non AC cars retained the piercings at the back by the cowl, but there was no trim insert there.
In 71, All the hoods (except W25) had rear cowl piercing. The hood in your pic is definitely 1970 though.
#43
Picture for you Ted,
1970 442 standard hood. I looked in the 1970 Assembly Manual [see section 11, pages 172 / 174] and it suggests that the following models got this : 3677, 3687, 3577, 3587, and 4400. Interestingly it also shows piercing on the hood for the Oldsmobile script above the LS headlights! The 1970 CS (non 442) had a different hood (stock from factory).
As you know, the CS vert was a candidate for 442 so anything goes there. If the hood came on your ??non 442??? CS I'd suggest that a PO sometime put it on. Possibly by choice or as replacement from available parts after collision? Just guessing on how it got there.
![](http://i.ebayimg.com/00/s/NjAwWDgwMA==/z/bIUAAOSwd4tT2nx0/$_4.JPG)
#45
the 70 has these metal, almost an insert whereas the 72 S does not....
you are correct Allan, the hood was put on the car
thanks for clearing that up for me.....good imfo!
#46
Against everything I have learned thus far, I am going to save this car.
WINTER PROJECT!
I must be nuts!
#49
This is weird that I am quoting myself, but I could not find another pic of the breather.....the car is in storage....can anybody help me to identify the breather...it is not original to the car, and a friend said it was from a 68 or 69 HO or a w31
....anywhere I can look for numbers or something that would identify it as being so?...any help would be appreciated....
Thanks,
Ted
Post number 20 is a pic of the breather
Thanks,
Ted
#52
Allan, the Olds 71-72 dual snorkel has 2 completely different snorkel sizes, one long and one short. The breather pictured above has 2 long snorkels that are identical. It looks to be 71-72 GTO, maybe 70 also.
#55
#57
The Z that is right in front of the trim code. No one seems to know for sure what it means, though there are several cars that have it.
If I remember correctly, based on a different year's build sheet, some think it means the car was destined for Canada. I am of the opinion that it doesn't mean this, as my 4 door has the Z and it never was, nor intended to be, in Canada. It just has something to do with the interior because on the Broadcast card the Z is in the interior section.
No matter, you have quite the gem there. A convertible with power windows is the way to go. Who wants to stretch across the car and crank down windows?
#59
OH NOOO! ANUTTER project??? You'll need to build a storage shed just for the cars in waiting!
![EEK!](https://classicoldsmobile.com/forums/images/smilies/eek.gif)
You got bitten purty bad son! Honest Teds Resto Shop - Make us an offer. Honestly - we can't refuse!
![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
#62
![Talking](https://classicoldsmobile.com/forums/images/icons/icon10.gif)
here she is...all there. 455 with a Holly G heads F font block and headers and it runs!. Bench black interior,8 track, front disc and best of all the top works!
under the bondo is new metal...
#67
Thanks Adam
.. between the two I should be able to make one....although this one is all there. Good eye on the Keystones,,,they are in good shape. There is a GTO looking wing on it too, that actually does not look to bad.HeHe, I dig the **** carpet on seats, floor and bottom of the door panels, all which are good under all that carpet
halfmoontrail
March 17th, 2013 10:28 AM
