70 oil Sending Unit for gauge - 45 deg elbow
why are there two styles of the 45 deg extension/elbow for the gauge oil sending units. One has a short 45 deg top section, andl more tub. The other type has the same 45 degree section, but it extends further down the tub, so the tub is shorter., Both appear to be have the same overall length. which is correct? . Also, does any one make a factory correct sending unit with flat sides at the top, and the spade connector secured with the nut…thanks
68RocketAction
December 18th, 2014 11:19 AM
Del70
September 11th, 2012 06:45 AM
