70 dual gate shifter.
Old Dec 26, 2019 | 07:34 AM
tru-blue 442's Avatar
Old School Olds
Hi Fellas. Still gathering parts for the 70 442. I have the dual gate but am trying to figure out brackets for the NSS.
I'm not sure what I still need here but I have a nice top plate for a 71-72 I would swap for the parts I need.
Old Dec 26, 2019 | 09:49 AM
70Post's Avatar
Adam - I believe you need the bracket in the pic below and PROBABLY a flat metal "link"/arm the connects to this bracket (not shown) and then runs back and attaches to the switch itself (along with items to attach the link/arm to the bracket in my pic and to the NSS).
I have fabricated both myself in the past using originals for a pattern. I may be able to make a couple more. I think I also have at least the pin/clip that holds the link/arm to this bracket since I sourced a bunch of this stuff for rebuilding/restoring Dual Gate setups.
Old Dec 26, 2019 | 11:29 AM
Old School Olds
Thanks for that Patton. I probably need to send it off to you along with my breather. Were you able to source a lower piece to fix the broken one? I also have the complete shifter for the 70 still bolted in place but I don't think the NSS and link are the same between the two. I do believe the harness is the same however.
Old Dec 26, 2019 | 11:32 AM
70Post's Avatar
PM sent
Old Dec 29, 2019 | 07:48 AM
Old School Olds
OK, thanks to Eric Jensen I was able to source a NOS switch but if someone has the 2 brackets and the little galvanized short rod that
attaches to it I should be set. Thanks again all.
joesw31
Nov 30, 2019 09:10 AM
Troys Toy 70
Apr 25, 2019 05:01 PM
Mikel7099
Oct 20, 2013 07:51 AM
AGK
May 23, 2012 07:13 PM
317Cutty
Oct 8, 2011 04:01 PM
