70 Cutlass Supreme - new dash wood grain install question
Old November 15th, 2017, 09:07 AM
jc1671's Avatar
Hello - I purchased a new dash woodgrain for my 70 Cutlass Supreme and need your guidance on the best way to remove the original woodgrain along with the wiper ****/plate.
1. How to remove the current woodgrain, can I just pull on it or is there a chemical or other product that can ease the removal?
2. The new woodgrain came with a cutout big enough only for the wiper lever to fit through so I am assuming the wiper plate needs to be removed? If so is there a trick or do I pull it off and re-glue it after?
3. And if the plate needs to be remove which tool do I use to remove the wiper ****?
See picture attached.
Thanks in advance for your help!
Dash woodgrain
jc1671 is offline
Old November 15th, 2017, 09:45 AM
delete
droptopron's Avatar
I need to do this as well. To the best of my knowledge the plate is held on by speednuts that you have to access from behind. I'm not sure if its better to get them from underneath (I have an AC car) or to pull the gauge above it out.
droptopron is offline
Old November 15th, 2017, 09:48 AM
scott_442's Avatar
70 wood grain (burl wood?) is my favorite! I'm not sure about removing the old wood grain but a heat gun will most likely be needed to loosen up the glue. I'm sure someone that has actually done it will chime in.
As for the windshield washer switch plate (which I have done), that has to come off from the backside as it's held on by 2 really small nuts on 2 long studs. You'll have to use a small Allen wrench to loosen the set screw in the **** itself. Hope that Helps and that you have small hands!!
scott_442 is offline
Old November 15th, 2017, 10:05 AM
jc1671's Avatar
thanks -
442 for the washer switch plate, did you remove the above gauges or had to do it from under the dash?
jc1671 is offline
Old November 15th, 2017, 10:59 AM
scott_442's Avatar
I did it from underneath but mainly because I happen to be installing a new headlight switch at the same time. Not sure if you can get a good visual on the nuts from above as they are very small and recessed as I recall. And I had my seats out at the time so I didn't have to struggle much to get in position!
Old November 15th, 2017, 11:15 AM
jc1671's Avatar
Sounds good, thank you.
jc1671 is offline
Old November 15th, 2017, 11:27 AM
Dave26's Avatar
I have found it is easier to reach in through the gauge holes, especially if it’s an A/C car. I use a 1/4 inch drive with a 1/4 inch socket.
Dave26 is offline
Old November 15th, 2017, 12:24 PM
My442's Avatar
Remove the gauge bezel by taking out the 2 Phillips mounting screws that hold it to the dash.
Use a heat gun to soften the contact cement, and GENTLY pry up one of the corners......take your time.
To fasten the new wood grain, use contact cement.
My442 is offline
Old November 15th, 2017, 12:28 PM
delete
droptopron's Avatar
Just a standard 1/4" socket, not deep?
I can tell my sausage fingers and fat forearms are going to be an issue
Old November 15th, 2017, 01:06 PM
Dave26's Avatar
I use a combination of sockets and ratchets.
Dave26 is offline
Old November 15th, 2017, 01:55 PM
jc1671's Avatar
is it a dumb idea to place the new woodgrain over the old one? Had to ask..
jc1671 is offline
Old November 15th, 2017, 03:03 PM
My442's Avatar
Yes
My442 is offline
Old November 16th, 2017, 05:14 AM
delete
droptopron's Avatar
Even if you do, the trim plate for the wiper still has to come off. That sounds like the hardest part
Old March 24th, 2018, 11:47 AM
jc1671's Avatar
Finally getting to this project and now I am stuck on the windshield washer ****, i spend over 1 1/2 hours trying to remove the small pin that holds the **** with an alen rench and cannot, the screw may be stripped so any suggestions on how to remove the **** if I can't unscrew it? Do I have to suck it up break the **** with pliers and buy new one? Thanks.
jc1671 is offline
Old March 24th, 2018, 12:02 PM
dalilama's Avatar
It's not a pin - it is held on with a small allen set screw and will come off with a tiny allen wrench. I forget what size, but you may be using one too big or too small and just spinning on it or in it. If it truly is stripped not sure what your next step is...short of using needle nose pliers to hold the shaft behind it and using another pair of pliers to try to wiggle the know off.
Good luck!
dalilama is offline
Old March 24th, 2018, 12:09 PM
jc1671's Avatar
Thanks - I tried many different Allen wrench sizes and the one that seems to be the best fit does grasps the pin inside the **** but not very tight so when I turn it just spins.
jc1671 is offline
Old March 24th, 2018, 12:19 PM
dalilama's Avatar
Shoot some penetrant in there and let it soak overnight. Make sure you cover the dash with a rag. You may get lucky...
dalilama is offline
Old April 16th, 2018, 07:05 AM
jc1671's Avatar
Hi fellows - so I finally finished this little project but fixing one thing in my world means breaking 2 other things. I had to remove the TEMP gauge in order to access the screws behind the dash and after putting things back together my GEN light is now constantly on and my headlights don't work. Any ideas?
Could there be a short on the gauge if so how to I find out where and what would be the connection between the gauge and the headlights?
I checked all fuses and all are good. As always thanks in advance.
jc1671 is offline
Old April 17th, 2018, 05:54 AM
jc1671's Avatar
Any takers on this one, should I post this additional question under electrical? Thanks.
jc1671 is offline
Old April 18th, 2018, 04:32 AM
Sampson's Avatar
I would backtrack where you have been. Look for loose connections. The instrument cluster gauges and lights are grounded by the attaching screws that hold them in. Check for good connection there. Do the headlights not work or just the instrument lights? Check the connector at the back of the headlight switch to make sure it didn't pull loose while you were poking around behind the dash.
Sampson is offline
Old April 18th, 2018, 06:31 AM
jc1671's Avatar
The instrument lights do work and the side marker lights also work which is odd b/c I thought the headlights and side marker lights were connected. I checked for grounding on the cluster face plate and everything looked OK but will check again and get back with my findings. In the meantime thanks for the input and keep them coming.
jc1671 is offline
Old April 25th, 2018, 07:41 AM
jc1671's Avatar
Update - I traced the headlight wires to the headlight switch but could not see the wires since the space is so tight so I just squeezed the wires connected to the switch and the lights turned on..
As far as the GEN Light, that was still ON even after making sure the ground screw and plate were well connected. What I tried next was replacing the light bulb and when I did that the GEN light turned off however when I inspected the bulb that was in place I did not see anything wrong with it. I repeated the process 3 times, using 2 different bulbs and the original and each time the original bulb kept the GEN light on. Any ideas? Could the issue be with the bulb housing? Thanks.
jc1671 is offline
chip-powell
February 2nd, 2016 11:51 AM
chip-powell
January 30th, 2016 01:17 PM
BeenThere
March 3rd, 2015 07:09 AM
71cutlass_ragtop
March 2nd, 2012 06:11 PM
1987442
May 13th, 2007 03:55 PM
Quick Reply: 70 Cutlass Supreme - new dash wood grain install question
