70 Cutlass Center Link replacement - Pullers
Old Jun 7, 2020 | 01:19 PM
Del70's Avatar
A standard tie rod end pickle fork or puller does not look like it will be able to wedge into the center link/pitman arm joint - Is there a special tool/is a tool required to separate the center link joint from the pitman arm?
thanks
Old Jun 7, 2020 | 01:31 PM
I've always used a BFH by whacking the side of the joint area with the nut loosened.
Old Jun 7, 2020 | 02:06 PM
RandyS's Avatar
You can borrow a Puller from your local Auto Parts Store.
Old Jun 7, 2020 | 04:43 PM
I have the OTC front end kit. One of the two on the left will always do the job, depending on the car.
Old Jun 8, 2020 | 02:05 PM
Del70's Avatar
thanks! Picked up one of the the non-destructive pullers - worked perfect for all of the joints.
klleetrucking
17
Aug 24, 2019 05:51 PM
ART T
Dec 19, 2016 10:31 AM
John1963
Jul 1, 2015 08:20 PM
delta88_frankfurt
Mar 7, 2015 07:54 PM
TicTocTach
Aug 14, 2014 10:11 AM
