70-72 power window question
Old Jan 16, 2020 | 11:14 AM
Hoffman2099's Avatar
I found a guy who has a power window set up from a 1970 monte carlo for sale. Would that be correct to put into my 72 cutlass? Do the power window buttons between 70 and 72 differ? Thanks
Old Jan 16, 2020 | 06:27 PM
2blu442's Avatar
A member on this thread said he used a Monte Carlo setup in his car.
https://classicoldsmobile.com/forums/general-discussion-33/71-cutlass-power-windows-swap-130127/
I
don't remember if the 1970 had rounded or square corners on the switches. The 1972 should be squared corners. But changing switches is easy, I've got a box full of power window and power lock switches. John
Old Jan 16, 2020 | 07:44 PM
4speed455's Avatar
https://classicoldsmobile.com/forums...s-swap-130127/
Fixed your link.
I am the member in question. I used the 72 Monte Carlo power windows in my 70 Cutlass convertible. I used the squared switches from the 72. The correct 70 switches are rounded. They look a little different but fit and function the same.
If your your switches are in good shape and you want the correct 72 style I would be willing to swap mine for the correct 70 style. If your switches are rough I may have a second set correct for 72 to sell.
Old Jan 16, 2020 | 09:22 PM
2blu442's Avatar
yellowone
Sep 24, 2019 03:56 PM
pfergy600
Sep 9, 2016 11:03 AM
Convertcrazed
Mar 28, 2016 06:32 PM
STR-8_CHARGIN
Jan 24, 2013 05:40 PM
rodan
Apr 9, 2012 05:45 AM
