70 442 cam replacement
You do not need to remove the engine. Would be a great idea anyway. That way you can remove the pan and hot tank all the years of crud that has built up.
If you don't remove the engine, you will need to remove the radiator, A/C condenser(if you have A/C), intake, distributor,rocker arms, push rods, harmonic balencer, water pump, front cover, fuel pump.
A days worth of work. Good luck.
Gene
Gene
Gene
Gene
Don't have any history...however...seller did volunteer to me that they tried the original intake and carb with the current cam and roller rockers and the car just wouldn't run right. It actually runs nice as is, but I'm more of a purist and want to return it to stock. I don't see why with the original intake, lifters, rockers, pushrods and carb it shouldn't.
en you take the cam out, be sure
If you have the stock parts, just put it together with them. Sell the performance parts you don't want.
When you take the cam out be sure to keep the lifters in the order they come off the cam. The roller rockers are no big deal, actually an improvement over the stock rockers. Plus the valve covers cover them.
Did you get the intake and the carb that belong to this car and match with numbers?
Where in SoCal are you?
Gene
Gene
