69 Cutlass Door Rubber Bumper?
Old May 10, 2021 | 07:35 AM
Phoenix8990's Avatar
69 Cutlass Rubber Bumper? Where does it go
I'm trying to install these guys on the doors but can't get them in. I've tried pushing a punch through the hole in the center, wiggling them etc. to no avail. The same with the hood wedges. What do I need to know?
thanks,Steve
Any idea where this one goes?
Old May 10, 2021 | 07:43 AM
Loaded68W34's Avatar
Use spray silicone or another lubricant liberally on the rubber part before installing. From there, I usually work them in carefully with a small pick or screwdriver.
Old May 10, 2021 | 09:08 AM
I'll give it a try, thanks
Steve
Old May 10, 2021 | 10:23 AM
As others mentioned, silicon spray helps. As does a little heat.
Old May 10, 2021 | 10:42 AM
Vaseline or liquid dish soap works well also.
Old May 10, 2021 | 12:30 PM
Don't use Vaseline or petroleum based lubricants. They will deteriorate the rubber over time. Silicone grease is your best bet. I've just recently installed a similar bumper on my 62, and I had to "encourage" those tapered retainer ***** into the holes with a small flat-blade screwdriver. Letting the rubber heat up in the sun and soften also helps.
Old May 10, 2021 | 03:27 PM
In case the sun isn't shining (even if it is), I like to boil a small pan of water, remove the water from the stove and drop those little buggers into the hot water - they'll shrink up admirably. Rubber is peculiar to a degree - it shrinks when heated, expands when cold (as the result of the polymer chains relaxing and becoming elongated).
Old May 10, 2021 | 06:30 PM
I had some white silicone grease and worked them in. Very interesting the shrinking effect hot water has on rubber. thanks to all for the help. I know I'm getting old, I just don't want to be old and stupid! Which is how I feel with questions like that one.
Steve
Mar 9, 2021 08:55 AM
Big Dawg
May 18, 2020 12:27 PM
sundancegl
Feb 12, 2017 08:15 AM
matt69olds
Jul 14, 2010 01:46 PM
Gert3116
Sep 11, 2007 09:47 PM
