69 cutlass brake shoe spreader bar
Old July 2nd, 2014 | 07:56 AM
Niko's Avatar
I have a 69 cutlass and have some guys doing a little work on it. The called me and said that the front brakes are missing the brake shoe spreader bar and they cant locate one. My question is does anyone have a picture of this? and is it a spreader bar or spacer bar. Also, if anyone has any front bumper brackets they are looking to sell please let me know.
Old July 2nd, 2014 | 08:01 AM
Run to Rund's Avatar
Are they confusing the front with the back brakes which use such a bar for the emergency brake's manual activation?
Old July 2nd, 2014 | 08:02 AM
Niko's Avatar
no.. I asked them twice and they said the front. I believe it is called a space bar.
Old July 2nd, 2014 | 09:06 AM
1970-W30's Avatar
I wouldn't trust those "guys" doing your brake work, doesn't seem like they have any brake work experience. Only the rear shoes use the bar........
Old July 2nd, 2014 | 09:19 AM
boese1978's Avatar
Pretty sure you mean this "bar / Spacer" right?
Octania's Avatar
front drums are different from rear drums
Buy 'em a Chilton's?
http://www.ebay.com/itm/Chiltons-Rep...item25916e4dc4
Old July 2nd, 2014 | 09:25 AM
Sugar Bear's Avatar
If it is the flat bar with a slot in each end, has a spring on one end and is above the axle it is used on the rears only. Nice that they observed the difference between the front and rear; however, they may lack experience on cars with front drum brakes.
Hopefully they know that on each wheel there is a smaller shoe and a larger one. On each wheel the shoe with less lining goes forward. The backing/shoe that the friction material is mounted is often the same and it is easy to make the mistake of putting them on reversed.
Old July 3rd, 2014 | 07:42 AM
Octania's Avatar
Good point. The old leading/ trailing different shoe length trick.
Plus, the fronts are typically much wider.
LH thread adjusters on the RH side of the vehicle... proper way around...
Any mechanic should understand the function of the parts they are working with. If you understand the function of that "spreader bar" then you know why there isn't one on the front brakes.
1970-W30
November 3rd, 2013 06:19 AM
Moose2
October 10th, 2011 09:43 AM
russell-t
Brakes/Hydraulic Systems
May 19th, 2011 06:26 AM
65superrocket
April 30th, 2009 05:11 PM
nebuckeye
April 11th, 2009 10:12 AM
Quick Reply: 69 cutlass brake shoe spreader bar
