68 delta 88 with crank windows all the way around . I’m trying to lower the back 2 windows . They get about 1/4 of the way down and it gets real stiff and i don’t wanna push it. Looking for any recommendation on what to do to safely get them down . Lubricant ideas etc ?
The rear windows don't get used as much as the front ones. The grease on the tracks gets hard over time. Unfortunately you need to remove the back seat and inside upholstery panels to access the window mechanisms. It's also possible that the plastic rollers have broken. Use silicone grease.
