68 Cutlass S auto to manual swap
My father restored this car when i was born in 1985 and it still looks great. Since then he has passed and I really want to pursue what he was going to do. Ok, I'd really like to change out the 2 speed auto to a 4 speed manual and change gearing or rear end to lower gears. This car has to have very high gears as it is now. What all is needed for the trans swap along with components (trans number, part numbers, difficulty in accomplishing etc.) and components to change to 3.73 or straight swap of the rear end. I'm open to all suggestions other than selling the car ha. It's one of those cars that will live in my family as long as I'm alive and hopefully there on out. I'm not the best mechanic but I do pretty well. Thanks guys, I'm happy to be apart of the forum now.
Jared
Jared
Welcome to the site.
The biggest hurdle to a manual trans is having the crankshaft drilled for a pilot bushing/bearing..the correct one, not an adapted version. Getting the parts is the easy part but still require some effort. Doing the work or having it done is another.
Having your rear diff changed is another hurdle. I think you might consider this one first.
You can have your current rear swapped out entirely with what you want for your goals, or just the parts inside. This all depends on parts availabilty and budget.
I think changing the rear gearing will improve your opinion of the car (make it more fun) very quickly and you can do the trans swap later.
None of this is cheap but might give you a leaping point to start from.
When you get a chance, upload some photos of your car, or share some more about what you goals are.
I forgot. Didn't see the 1 post. Welcome Jared. Were all here to help. And as don71 aid the 4 speed swap is very involved especially the sourcing of OEM parts. And it's expensive expect to pay at least 2500 just in parts. Also the issue with drilling the back of the crank to accept either input shaft bearing 7109 or a bronze one. It's a bear to do in the car. Ur better off making it a 3 speed auto something like a turbo 350. Easy swap
ALL manual transmissions require a pilot bearing in the crank. An Olds motor originally bolted to an automatic will not typically have the crank drilled for this pilot bearing.
I had my motor built by by a well known engine builder and never asked or checked before putting the engine in the car. I would love a manual transmission but I don't know about cutting a hole in the floor and I don't feel like removing my auto transmission to to check the crank.
The cars been running so good I like the fact I can jump in and cruise. Lol
Would be insane with a 5 speed tremec...
Now, maybe over the wintertime...................
ignachuck
June 12th, 2015 05:29 PM
borgerding
December 7th, 2014 06:50 AM
Bobac455
February 6th, 2014 02:04 PM
