68 cutlass right side alternator bracket
Does anyone know of anyone with right side alternator brackets for 1968 cutlass? Would like to install aftermarket underdash a/c. see that water pump pulley has 3 belt slots, will only align properly with middle one for alternator if you move alternator to right side which appears to clear the power steering brackets. I already picked up the a/c oem bracket for left side, which looks like will then align with rear belt slot.
I left a message for 2blu442 (John) from a feb 2012 post. Ideally in need of the entire right side bracket, the head bolt with thread on top. In additon the water pump bolt with thread on top where the a/c bracket support connects. I've called 2 of the 4 aftermarket ac companies and neither offers a bracket and indicated fabriation necessary. Much Thanks
Neil
Neil
442mark
September 30th, 2017 01:06 PM
xerxes600rr
August 30th, 2011 06:43 AM
