67-69 cutlass auto console question
Old Feb 14, 2012 | 08:32 PM
66-3X2 442's Avatar
I'm in the process of putting the console top back together on the 68 we're working on. In the assembly manual,it shows a 'plate' under the selector lens. What does this plate do? is it some kind of colored/solid plate? I do not have one that came with the console top,so I need to know what it is/does and if anybody has one for sale.
Old Feb 15, 2012 | 08:29 AM
Beob's Avatar
In between the chrome top plate and the body of the cosole there should be a plastic plate which has the holder for the light bulb that lights the indicator.
Rob
Old Feb 15, 2012 | 08:41 AM
66-3X2 442's Avatar
Rob
Yes,I have that part,the slider and the lens but it shows a plate under the lens. There's an illustration from the assembly manual that shows said plate in this link.
http://72.22.90.30/phpBB2/viewtopic.php?t=81303
Old Feb 15, 2012 | 09:21 AM
The plate under the lens is a diffuser. Without it, you get one bright spot directly above the bulb and the other letters are dim. The diffuser keeps all the letters at the same brightness by diffusing the light from the bulb.
Old Feb 15, 2012 | 09:26 AM
Oldsmaniac's Avatar
There is also a filler that the shifter goes thru that slides with the shifter. ( Maybe same part referred to above) It is a filler to keep light, heat, fumes or watever inside the console and covers the slot cutout for chrome shifter handle. These plastic fillers sometimes break as they are thin on the sides.
Old Feb 15, 2012 | 09:37 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
The diffuser plate Joe mentioned will be a sky blue colored plate.
Old Feb 15, 2012 | 11:53 AM
66-3X2 442's Avatar
Joe
Yes,I figured that what it is and I have confirmed with another Olds buddy that it's solid steel painted blue. If it's steel,how does the light get through or does it just filter around it? It probably helps keep the heat from the bulb off the indicator lens also. The plate is tapered on the forward end and has a hole in the aft end. I can't find one repo,so I guess used will be it. Thanks guys for the help and I may be looking for a plate.
Mike
Old Feb 15, 2012 | 11:55 AM
66-3X2 442's Avatar
Got that part,it's available repo,just got to find that plate.
Mike
Old Feb 15, 2012 | 02:32 PM
rroth01's Avatar
From: Orion Township Michigan 30 Miles North of the Murder City
Mikey
If you can make a paper pattern of the cavity I may be able to get it laser cut for you.
Or send me the part and I will get it cut for you.
Ron
Old Feb 18, 2012 | 03:40 PM
66-3X2 442's Avatar
OK,I found a diffuser plate and one side is painted light blue,the other side is bare. My question is,what color if any is the black plate painted in the bulb area. I have seen one painted white and was told of two others painted the light blue,which is correct? The black plate I have has no hint of either color. This is the black plastic plate that has the four holes and is held to the top plate with four nuts. Any and all help is greatly appreciated.
Mike
ignachuck
Jun 12, 2015 05:29 PM
MN71W30
Apr 1, 2013 08:41 PM
69442murph
Nov 13, 2011 06:21 AM
1k442
Oct 13, 2011 12:09 PM
nova7579
Sep 30, 2010 04:34 PM
