67-69 cutlass auto console question
I'm in the process of putting the console top back together on the 68 we're working on. In the assembly manual,it shows a 'plate' under the selector lens. What does this plate do? is it some kind of colored/solid plate? I do not have one that came with the console top,so I need to know what it is/does and if anybody has one for sale.
http://72.22.90.30/phpBB2/viewtopic.php?t=81303
Yes,I have that part,the slider and the lens but it shows a plate under the lens. There's an illustration from the assembly manual that shows said plate in this link.
There is also a filler that the shifter goes thru that slides with the shifter. ( Maybe same part referred to above) It is a filler to keep light, heat, fumes or watever inside the console and covers the slot cutout for chrome shifter handle. These plastic fillers sometimes break as they are thin on the sides.
Yes,I figured that what it is and I have confirmed with another Olds buddy that it's solid steel painted blue. If it's steel,how does the light get through or does it just filter around it? It probably helps keep the heat from the bulb off the indicator lens also. The plate is tapered on the forward end and has a hole in the aft end. I can't find one repo,so I guess used will be it. Thanks guys for the help and I may be looking for a plate.
Mike
Got that part,it's available repo,just got to find that plate.
Mike
Mike
ignachuck
Jun 12, 2015 05:29 PM
MN71W30
Apr 1, 2013 08:41 PM
1k442
Oct 13, 2011 12:09 PM
