67 442 quarter emblems
Old May 22, 2013 | 05:26 AM
jlcaver's Avatar
Hello---is there any way outside of completely removing the quarters to replace the 442 emblems on a 67? Thank you in advance for your reply.
Old May 22, 2013 | 06:52 AM
wmachine's Avatar
Trying to remember member
I presume by "quarters", you mean front fenders?
Old May 22, 2013 | 07:15 AM
Sometimes you can pry them off. Double sided tape or trim adhesive to reattach.
Old May 22, 2013 | 07:28 AM
66400's Avatar
Remove the lower fender heel bolts, also remove a lot of the inner fender well bolts. That will provide enough clearance to slip your hand in to access the nuts on your emblem.
Henry
Old May 22, 2013 | 09:07 AM
Run to Rund's Avatar
GM did not use double sided tape back then. They used studs cast into the emblem, going through a hole punched in the body panel, and secured with a stamped steel nut on the inside.
rcktdoc
Apr 12, 2014 03:25 PM
KZ442
Jun 18, 2011 10:34 PM
noleduck
Sep 3, 2009 06:55 PM
johnyyy
Feb 17, 2009 06:55 PM
