66 starfire questions
i finally got around to looking at my new project car
1966 starfire
now my first question
i thought it had a turbo 400 transmission
but the shifter has
PNDSL
what does the S mean?
thanks in advance
scott
1966 starfire
but the shifter has
PNDSL
thanks in advance
scott
The switch pitch TH400 is an incredible trans. When I was a kid (16-17) my second 442 was a 67 with an automatic. I drove it like I was trying to break it most of the time. I would leave a stop and let it just shift the car automatically then at about 15-20 mph would pull it to 1st and stand on it and that car would come unglued. I had put a 3:55 posi in it. that car was so much fun. I sure treated it crappy and it took it for a long time.
If you have an owner's manual for the car, check in there.
Correct.
I don't have a '66 manual, but I do have an owner's manual for my '67 Delta. Here's what it says in the section on the transmission.
Correct.
Don't confuse marketing hype with reality. The trans is a TH400, period. There are three (count 'em) gears. First is 2.48:1, Second (or Super, or L2, or whatever you want to call it) is 1.48:1, and third is 1.00:1. Yes, this is a switch-pitch, but that doesn't change the mechanical gear ratios, it only changes the stall speed (and thus torque multiplication) of the converter.
If you manually shift into "L", the trans will stay in first. If you manually shift into "S", the trans will downshift into second if you are currently in third. It will automatically shift between first and second depending on load and road speed.
viper771
October 26th, 2011 10:42 PM
viper771
September 15th, 2011 03:47 PM
